21-08-2015 #1
I can successfully profile cut through 120mm deep Kingspan insulation board using just a ground 8mm drill bit. By running the cnc really slowly and also keeping the spindle speed right down to 2000rpm.
I wanted to use the same process to cut through 120mm blue Floormate Styrofoam BUT it acts completely differently. I need a new approach as the drill is melting the foam and getting gummed up.Wrong speed? spindle going to fast and the drill bit running toohot?-wrong cutter?
Perhaps the Styrofoam green acts differently to the blue?
The reason i'm pursuing using the Styrofoam is to use to make masterforms for aluminium casting. I can pour the aluminium directly onto the styrene which is vapourized on contact with the alu. Kingspan hasa higher fire rating and wont dissolve in the same way.
Has anyone written an extensive list or seen a link to a list of polystyrene and foam plastics and how to router, carve into them andwith which mill ends and feeds and speeds?
Any help much appreciatedLast edited by marbles; 21-08-2015 at 11:33 PM.
23-08-2015 #2
Different materials I think, kingspan is polyisocyanurate, PIR foam which machines realy well.
Styrofoam is polystyrene , guessing need a lot sharper cutter to stop it chewing.
Frog are the name springs to mind with long cutters for foam
http://www.3dcutting.comLast edited by Musht; 23-08-2015 at 12:44 PM.
The Following User Says Thank You to Musht For This Useful Post:
Polystyrene Cutter
By kingcreaky in forum Marketplace DiscussionReplies: 2Last Post: 12-05-2014, 08:44 PM -
BUILD LOG: New build - fixed gantry mill using extruded profile
By toolchimp in forum DIY Router Build LogsReplies: 3Last Post: 09-11-2012, 04:10 PM -
Cutting bits nomenclature - help requested
By DanielF in forum Tool & Tooling TechnologyReplies: 2Last Post: 12-05-2012, 04:53 PM -
Polystyrene hardening product
By GASANT in forum Marketplace DiscussionReplies: 4Last Post: 18-04-2012, 02:25 AM -
Extruded alu and mounting rails on em
By CNCBlug in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 04-03-2010, 06:50 PM
