    I've been milling insulation board for ages with ground drill bits and ball mill ends but a someone requires styrofoam to be milled and it looks like it requires a different mill. There are specialist companies like Styrotec who make solid and hollow bits for polysterene but they are super expensive.
    Where can I buy a cheaper alternative rotary rasps in 6-8 or 10mm diameter that will cut 120mm of cutting depth? see pics
ID:	15919   Click image for larger version.
    Quote Originally Posted by marbles View Post
    hi mate, did you have any luck..?
    ricicnc.com has some spirals and olivercorp.com make custom stuff... but where did you end up getting yours from and how much?
    I buy from Ricicnc.com. I've just received an order from them for 8,12,16mm radius endmills all with a custom shank reductions. I dont have the invoice for those to hand but I bought a pair of R6 HSS ball endmills from them in 2018, deetz below. Three weeks from order for delivery. Couldnt find anyone in the UK to match.
    D12XR6X150X200 4T foam mill bits, unit price $21, Qty 2, carriage $34, total $76
    Quote Originally Posted by daveverrall View Post
    cheers.. do they hold up well?
    have you cut ply with them?
    I wouldnt use them on plywood. I only use these on EPS and PIR foam at 12mm diameter and 200mm long they would just snap cutting plywood. Yes they do hold up well i've have several keep sharp for ages but i've also snapped a few just by taking too deep a cut with too large a stepover into PIR (like100mm pass at 80% stepover)
    ok.. have you seen the plywood in the centre of a surfboard.. that's what it would cut..
    Can you post an image or diagram
    Ok so its a bit of 4mm or something. Horizontally or vertically down the centre? TBH need a bit more information to discuss solutions.
    If its just a single thickness sheet of ply and you know the depth can you not set up a cut path with a 2 flute just to cut the ply then have another toolpath and cutter for the foam? I have 12mm 2 flute endmills up to about 100-120mm which will take down that ply in just a few layers. it all depends how deep you need to mill.
  1. FOR SALE: milling slot cutter 20mm new for sale
    By chalfontcrew in forum Items For Sale
    Last Post: 04-02-2013, 12:18 AM
  2. Which Plasma Cutter to buy?
    By AndyG in forum General Discussion
    Last Post: 02-12-2011, 09:34 AM
  3. cutter for MDF
    By deannos in forum Tool & Tooling Technology
    Last Post: 16-10-2011, 09:33 PM
  4. cutter chipload
    By johngoodrich in forum Tool & Tooling Technology
    Last Post: 17-09-2011, 01:02 PM
