Thread: It's alive! Well.......almost
Have you tried swapping the z over to the x or y just to test. Post the ini and hal file .. ..Clive
24-08-2015 #2
I hope you get this going right Thomas it looks to be a lot of fun.
You mention Jazz I sure wish he was still on the forum, in my view the forum has lost a great guy and it just isn't the same without him. He was a great help to me nice to talk to.
All the best
Suesi
25-08-2015 #3
Hi there thanks for the reply.
I have just tried swapping the z stepper cables with the y and the z axis moved fine, the y then had the problem. So does this tell me that the wiring is fine but there must be something wrong with the mx3660 unit?
I hope that's not the case! As I bought this over a year ago which means my warranty will have run out! Even though it is basically brand new.
25-08-2015 #4
25-08-2015 #5
Apologies for missing your previous question.
i cannot upload the .hal and .ini files, so I'm presuming you just mean copy and paste the content?
the .hal file:
# Generated by stepconf at Mon Aug 24 20:58:12 2015
# If you make changes to this file, they will be
# overwritten when you run stepconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt probe_parport
loadrt hal_parport cfg="0x378 out "
loadrt stepgen step_type=0,0,0
addf parport.0.read base-thread
addf stepgen.make-pulses base-thread
addf parport.0.write base-thread
addf stepgen.capture-position servo-thread
addf motion-command-handler servo-thread
addf motion-controller servo-thread
addf stepgen.update-freq servo-thread
net spindle-cmd <= motion.spindle-speed-out
net xstep => parport.0.pin-02-out
net xdir => parport.0.pin-03-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-05-out-invert 1
net ydir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
net zdir => parport.0.pin-07-out
net estop-ext <= parport.0.pin-15-in-not
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 1
setp stepgen.0.dirhold 210769
setp stepgen.0.dirsetup 210769
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [AXIS_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 1
setp stepgen.1.dirhold 210769
setp stepgen.1.dirsetup 210769
setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL
net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable axis.1.amp-enable-out => stepgen.1.enable
setp stepgen.2.position-scale [AXIS_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 1
setp stepgen.2.dirhold 210769
setp stepgen.2.dirsetup 210769
setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable axis.2.amp-enable-out => stepgen.2.enable
net estop-out <= iocontrol.0.user-enable-out
net estop-ext => iocontrol.0.emc-enable-in
loadusr -W hal_manualtoolchange
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
the .ini file:
[EMC]
MACHINE = Linux-CNC-Router
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cnc/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
[FILTER]
PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image
PROGRAM_EXTENSION = .py Python Script
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 20769
SERVO_PERIOD = 1000000
[HAL]
HALFILE = Linux-CNC-Router.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 5.00
MAX_LINEAR_VELOCITY = 50.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 28.5882806105
MAX_ACCELERATION = 50.0
STEPGEN_MAXACCEL = 62.5
SCALE = 800.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 250.0
HOME_OFFSET = 0.0
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
SCALE = 800.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 250.0
HOME_OFFSET = 0.0
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 25.0
STEPGEN_MAXACCEL = 31.25
SCALE = 800.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 0.001
HOME_OFFSET = 0.0
One thing I have just noticed is that when im in the step config wizard and i click on the 'test this axis' button. my z axis moves fine?
25-08-2015 #6
Ok Just had a quick look see this:-
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 25.0 this should be a lot higher
SCALE = 800.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 0.001
HOME_OFFSET = 0.0
so the most it can move is .002mm So alter the Min limit and try again say -100 or what ever your Z isLast edited by Clive S; 25-08-2015 at 08:49 PM.
29-08-2015 #7
[QUOTE=suesi34e;71715]I hope you get this going right Thomas it looks to be a lot of fun.
All the best
Suesi
Hi, I have been very busy for the ast few weeks (a situation that will continue for a while as I am busy building an 18 foot fast fihing boat and am converting a van into a camper to pull it!!). Yuo mention that Jazz has left the forum - is this really true? If so it is very sad, as Jazz is one of if not the most helpful and experienced members,
and will be sorely missed. G.Last edited by GEOFFREY; 29-08-2015 at 10:12 PM. Reason: typo
WANTED: TB6560 + PSU, Drivers, BOB's, Nema 23 Kits DEAD or ALIVE
By longy in forum Items WantedReplies: 4Last Post: 16-06-2014, 04:15 PM -
It`s alive
By gorbo in forum General DiscussionReplies: 4Last Post: 16-11-2010, 08:09 PM
