Thread: It's alive! Well.......almost
24-08-2015 #1
Hello all!
I haven't posted on here for a good while as I've been a very busy boy (not machine building unfortunately) but at the weekend I decided to get on with it and get my machine actually moving.
I did post on here about 18months ago with regards to my build and I got some very helpful advice from several members (jazzcnc in particular) when it came to getting the electronics right. I purchased the leadshine MX3660 unit to drive my steppers which is a very nice bit of kit especially for a newbie machine builder like me.
I'm using linuxcnc. All seems to working well except the z axis. The x and y work fine which is why I'm confused as to why the z axis is not moving. All the steppers are wired up the same (parallel) and the lead screws the same on all 3 axes (4mm pitch trapezoidal). The only difference is the z is using a pulley and belt while the x and y are directly coupled.
The x and y move fine in all directions when holding down the jog key, whereas the z just stalls. If I keep pressing the jog key the stepper moves tiny amounts at a time but it won't feed or jog at all.
I'm kind of lost as to what I have done wrong as each axis has been setup exactly the same in both the Linux software and on the leadshine unit jumpers. Or am I missing something simple?
I have uploaded a video on YouTube to make it a bit easier to explain.
http://youtu.be/HdqXq71MUcE
Please excuse the very poor narration lol.
24-08-2015 #2
Have you tried swapping the z over to the x or y just to test. Post the ini and hal file .. ..Clive
24-08-2015 #3
I hope you get this going right Thomas it looks to be a lot of fun.
You mention Jazz I sure wish he was still on the forum, in my view the forum has lost a great guy and it just isn't the same without him. He was a great help to me nice to talk to.
All the best
Suesi
25-08-2015 #4
Hi there thanks for the reply.
I have just tried swapping the z stepper cables with the y and the z axis moved fine, the y then had the problem. So does this tell me that the wiring is fine but there must be something wrong with the mx3660 unit?
I hope that's not the case! As I bought this over a year ago which means my warranty will have run out! Even though it is basically brand new.
25-08-2015 #5
25-08-2015 #6
Apologies for missing your previous question.
i cannot upload the .hal and .ini files, so I'm presuming you just mean copy and paste the content?
the .hal file:
# Generated by stepconf at Mon Aug 24 20:58:12 2015
# If you make changes to this file, they will be
# overwritten when you run stepconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt probe_parport
loadrt hal_parport cfg="0x378 out "
loadrt stepgen step_type=0,0,0
addf parport.0.read base-thread
addf stepgen.make-pulses base-thread
addf parport.0.write base-thread
addf stepgen.capture-position servo-thread
addf motion-command-handler servo-thread
addf motion-controller servo-thread
addf stepgen.update-freq servo-thread
net spindle-cmd <= motion.spindle-speed-out
net xstep => parport.0.pin-02-out
net xdir => parport.0.pin-03-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-05-out-invert 1
net ydir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
net zdir => parport.0.pin-07-out
net estop-ext <= parport.0.pin-15-in-not
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 1
setp stepgen.0.dirhold 210769
setp stepgen.0.dirsetup 210769
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [AXIS_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 1
setp stepgen.1.dirhold 210769
setp stepgen.1.dirsetup 210769
setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL
net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable axis.1.amp-enable-out => stepgen.1.enable
setp stepgen.2.position-scale [AXIS_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 1
setp stepgen.2.dirhold 210769
setp stepgen.2.dirsetup 210769
setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable axis.2.amp-enable-out => stepgen.2.enable
net estop-out <= iocontrol.0.user-enable-out
net estop-ext => iocontrol.0.emc-enable-in
loadusr -W hal_manualtoolchange
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
the .ini file:
[EMC]
MACHINE = Linux-CNC-Router
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cnc/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
[FILTER]
PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image
PROGRAM_EXTENSION = .py Python Script
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 20769
SERVO_PERIOD = 1000000
[HAL]
HALFILE = Linux-CNC-Router.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 5.00
MAX_LINEAR_VELOCITY = 50.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 28.5882806105
MAX_ACCELERATION = 50.0
STEPGEN_MAXACCEL = 62.5
SCALE = 800.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 250.0
HOME_OFFSET = 0.0
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
SCALE = 800.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 250.0
HOME_OFFSET = 0.0
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 25.0
STEPGEN_MAXACCEL = 31.25
SCALE = 800.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 0.001
HOME_OFFSET = 0.0
One thing I have just noticed is that when im in the step config wizard and i click on the 'test this axis' button. my z axis moves fine?
25-08-2015 #7
Ok Just had a quick look see this:-
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 25.0 this should be a lot higher
SCALE = 800.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 0.001
HOME_OFFSET = 0.0
so the most it can move is .002mm So alter the Min limit and try again say -100 or what ever your Z isLast edited by Clive S; 25-08-2015 at 08:49 PM.
25-08-2015 #8
Will add forum support for those file types shortly Clive...
.MeLee
25-08-2015 #9
25-08-2015 #10
Clive you are my hero!
It now works. I changed the z axis limits to be between -75 and 0. I was sure that I had tried it at that setting before but i must have got the numbers the wrong way round.
Thank you very much for your help. All I need to do now is buy a spindle and wire up the limit switches and it'll be ready for production work lol.
WANTED: TB6560 + PSU, Drivers, BOB's, Nema 23 Kits DEAD or ALIVE
By longy in forum Items WantedReplies: 4Last Post: 16-06-2014, 04:15 PM -
It`s alive
By gorbo in forum General DiscussionReplies: 4Last Post: 16-11-2010, 08:09 PM
