    I have been working on my project for some time but have just now gotten around to write about it.
    My machine is the SIEG Super X2P HiTorque Mill from Arceurotrade.co.uk
    The ball screws I’m using are from Isel and the 16 mm version, this was mainly because of the very limit space under the X and Y axis.
    My controle is the Eding CNC CPU5A4 Starter 4 axes in combination with a Triple Beast from benezan-electronics.de and one DM556 Leadshine Digital 18-50VDC 0,5 - 5,6A.
    After stripping the X2 from all not need for the conversion I started milling and drilling for the central lubrication system.
    And milling out for the ballscrew ball-nuts.
ID:	16004   Click image for larger version.
ID:	16001   Click image for larger version.
ID:	16003   Click image for larger version.
ID:	16002   Click image for larger version.
    Slow progress and updates on the project sorry, I have finished the Y axis and made a special bearing mount block for the Y axis because of the limit space if I want to install it under the Y axis (this is a standard bearing mount not the special mount block).
    And another view
    I have also made some progress on the enclosure for the mill using 4x4 cm square steel pipes for the frame.
    First cutting the pipes
    And a bit of welding
    And some paint and some more welding and painting :-)
ID:	18172Click image for larger version.
ID:	18173Click image for larger version.
    I have also been working on the blocks for the x axis:
ID:	18175Click image for larger version.
ID:	18176Click image for larger version.
ID:	18177Click image for larger version.
  1. FOR SALE: SIEG SUPER X 3 PROJECT un finshed cnc conversion
    By dazza in forum Items For Sale
    Last Post: 12-03-2015, 05:28 PM
  2. Super sieg x3 conversions
    By dazza in forum Milling Machines, Builds & Conversions
    Last Post: 19-02-2014, 10:28 AM
  3. CONVERSION: Sieg Super X3 conversion
    By Sooty in forum Conversion Build Logs
    Last Post: 06-03-2013, 02:29 PM
  4. eBay: small milling machine Sieg Super X3
    By Fivetide in forum Items On eBay UK
    Last Post: 19-11-2012, 01:48 PM
  5. Sieg Super X3
    By Gary in forum Milling Machines, Builds & Conversions
    Last Post: 25-10-2008, 10:58 PM
