26-08-2015 #11
If i was doing the job i would also use a jig but slightly different, would make it with 2 holes with an L shape cross section, make all holes on the assembly the same pitch, so you would clamp the jig drill & tap first hole, shouldered bolt goes in that hole, do second hole, move jig down using the shouldered bolt in the second hole drill & tap third hole in so on, the jig can also be used on the clear holes.
Mike
27-08-2015 #12
Hi reefy,
For marking out the edge holes - although I've not used one, I've often thought about buying transfer or universal punches in case I needed to transfer holes:
Universal transfer punches or Transfer punch sets:
http://www.arceurotrade.co.uk/Catalo...unches-Scribes
With the holes drilled in the top surface of one plate you would align it to the edge of the other (using clamps, 90 degree blocks etc.) put the correct punch into the hole and 'transfer' the centre point onto the edge surface.
FOR SALE: Batch of 3 6082/T6 Aluminium Plates
By Solihull1 in forum Items For SaleReplies: 3Last Post: 26-02-2015, 10:04 PM -
SOLD: Aluminium plates/blocks with sawn edges and the odd minor surface scratch
By Solihull1 in forum Items For SaleReplies: 0Last Post: 06-12-2014, 11:12 AM -
RFQ: Small turned part. Cross drilled. quotes or advice please.
By jimbo_cnc in forum Projects, Jobs & RequestsReplies: 0Last Post: 23-06-2014, 08:41 PM -
RFQ: RFQ: 3 x M5 holes drilled and tapped/ +/- 0.01mm required
By neurofen in forum Projects, Jobs & RequestsReplies: 9Last Post: 25-01-2012, 04:26 PM -
Now if only someone invented a drill that drilled square holes.....
By HankMcSpank in forum General DiscussionReplies: 3Last Post: 20-10-2011, 10:07 PM
