I would put up a RFQ in the marketplace section here on the forum, are they fancy shapes, could you not drill and tap yourself?
.MeLee
25-08-2015 #2
If you're getting a drill press and they're just square plates (I'm assuming you're getting ecocast or tooling plate for the ground surfaces to put your bearings on?) then a bit of engineers blue, set square, steel rule, centre punch set, scribe and you've already got the hammer!! Mark up the holes, centre punch them, drill on your drill press, tap using your drill press as a guide to keep 90° (search youtube for videos) and bob's your uncle you've got a drilled and tapped plate.....
Alternately search for local machine shops who will mill the edges to your desired shape and drill and tap for you....but will be expensive!
FOR SALE: Batch of 3 6082/T6 Aluminium Plates
By Solihull1 in forum Items For SaleReplies: 3Last Post: 26-02-2015, 10:04 PM -
SOLD: Aluminium plates/blocks with sawn edges and the odd minor surface scratch
By Solihull1 in forum Items For SaleReplies: 0Last Post: 06-12-2014, 11:12 AM -
RFQ: Small turned part. Cross drilled. quotes or advice please.
By jimbo_cnc in forum Projects, Jobs & RequestsReplies: 0Last Post: 23-06-2014, 08:41 PM -
RFQ: RFQ: 3 x M5 holes drilled and tapped/ +/- 0.01mm required
By neurofen in forum Projects, Jobs & RequestsReplies: 9Last Post: 25-01-2012, 04:26 PM -
Now if only someone invented a drill that drilled square holes.....
By HankMcSpank in forum General DiscussionReplies: 3Last Post: 20-10-2011, 10:07 PM
