    Hi Kevin
    That's a very kind offer.
    The coupling in the link locates and is locked with a grub screw, yours just has a different clamping arrangement so it will be fine.
    Your coupling will have sheared for a reason, what you need to do is check that the gantry isn't binding for a start, but i would suspect it's probably a slight misalignment of the motor and ballscrew shafts causing the coupling to flex on each rotation and eventually metal fatigue results in a break.
    While your waiting for your coupling try and align the two shafts as best you can, if possible shim the motor to suite.
    Good luck
    Mike
    PS
    or what Lee said
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Smooth Steppers are finally available in UK !
    By rnr107 in forum Marketplace Discussion
    Last Post: 13-07-2012, 12:53 AM
  3. Finally bought a CNC router!
    By tumutbound in forum Machine Discussion
    Last Post: 15-12-2011, 10:15 PM
  4. Finally getting somewhere
    By m.marino in forum Machine Discussion
    Last Post: 17-02-2011, 12:33 AM
