Thread: 6040 finally packed in!
I like the idea of the rubber tubing couplings, though I would clamp it to the shaft with hose clips.
I had a coupler break and I replaced it with a similar one, but I wish I had thought of the rubber tube, it is a bodge, but in keeping with the standard of my MD machine.
Rob
10-10-2015 #2
Mike to the rescue again!
You are a a legend mate! This is exactly what I'm after!
I like the look of CNC4YOU. I'll have a good wee nosey at this now shortly!
Rob,
I've never heard of this particular bodge. I like it!
Sounds like it could pull one out of a hole in an emergency.
Can you elaborate please? What kind of tubing etc?
Cheers mate!
Kevin.
10-10-2015 #3
Hi Kevin,
I'm just echoing the posting from routercnc further back in this thread. All I am saying is that I would use hose clips to make sure the little fecker didn't slip. I would probably use a bit of gas hose as that is flexible and braided.
I haven't actually done it, but I would probably do it in preference to fitting the ones like yours that broke, even though I have a couple of them spare in a drawer.
I had a lot of trouble with the clamp type slipping and eventually drilled them out and bonded a slitted tube in as a shim to get the internal diameter right for the stepper shaft.
Cheers,
Rob
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Smooth Steppers are finally available in UK !
By rnr107 in forum Marketplace DiscussionReplies: 63Last Post: 13-07-2012, 12:53 AM -
Finally bought a CNC router!
By tumutbound in forum Machine DiscussionReplies: 12Last Post: 15-12-2011, 10:15 PM -
Finally getting somewhere
By m.marino in forum Machine DiscussionReplies: 5Last Post: 17-02-2011, 12:33 AM
