Thread: Hi Guys help please
Hi Jazzcnc so would i be ok just to swap the m542 for the 2m542 ? thnaks
08-09-2015 #2
Yes they will be fine.
Doesn't matter what make of drive the important details are the amps and Voltage. Provided the drive has amp setting which matches your motor spec and the voltage rating is 10% more than what your PSU is outputing then they will work fine.
Even then regards the amps it's not critical they match 100%. For instance if your motors are rated 4.2a and the nearist drive setting is 4a or 4.5 then you'll still be fine. In cases like this you would go to the nearest setting down. This applies to any make or model of drive.
The important part is the voltage. Never run the drives at there maximum rating and leave a safety margin of aprox 10%. This ensure you don't fry the drives from return energy the motors create when de-accelerating.Last edited by JAZZCNC; 08-09-2015 at 03:04 PM.
08-09-2015 #3
thanks for your help on this i get them ordered up and hope for the best lol
NEW MEMBER: Hi Guys
By TECNC in forum New Member IntroductionsReplies: 0Last Post: 22-01-2014, 01:15 PM -
NEW MEMBER: Hello to you Guys
By Ballot in forum New Member IntroductionsReplies: 2Last Post: 01-10-2009, 06:42 AM -
NEW MEMBER: Hi guys
By cookster in forum New Member IntroductionsReplies: 4Last Post: 02-07-2009, 08:49 AM -
NEW MEMBER: Hi Guys
By Wotsit in forum New Member IntroductionsReplies: 0Last Post: 13-06-2009, 01:10 PM -
NEW MEMBER: hi, guys!
By wendelius in forum New Member IntroductionsReplies: 1Last Post: 11-06-2009, 07:04 PM
