    It is almost as high as two toiled paper roils stacked.
    I'm currently thinking on how I'm gonna run my air lines.
    13mm ID from pump to the mill head and split it there to 2x6mm ID or do it directly at the pump....
    not sure yet , do you guys have tips ?
    (system won't let me edit the post above)
    What are you trying to do, a mist system? you need an reservoir under pressure and air coolant mix valve and 1mm nozzle, system pressure 2.5 bar. Datron uses direct pressure liquid pump and 0.4mm? nozzles or sth like that.
    aluminum best is done with 2 stage process:
    -roughing
    -finishing
    1 flute or 2 flute, up to three, depends on geometry and slot cut or no.
    6mm bit seems to be the best for home use
    try something conservative and speed it up / the feed rate/ and or increase the depth pass:
    12000RPM, 1.5mm pass depth , 800-900mm/min
    kerosene works best, or just mist spray proper coolant mixture
    you will do nothing without a coolant, just brake bits
    my test show that 4mm tubing/2.5mm inside/ is ok, so it does not matter in your case
    Yes I'm doing an mist system. I ordered two of these:
    http://www.ebay.co.uk/itm/Mist-Coola.../252043904329?
    I did some googling and other people seem to have good luck with these aquarium air pumps. Most of them use the 80 l/min models but recommended going 120l/min +.
    So I just got the biggest one. A compressor would be just to loud for my situation. And the paintbrush one's seem to have a hard time to keep up with the airflow.
    If it does not work out than I will just return it in 14 days and get my money back. In that case a paintbrush / real compressor will be the alternative.
    People who use compressors seem to be running these nozzles <1 bar so I think I'm alright.
    As a liquid I'm testing lamp oil or ethanol , these both should work out fine.
    The 280 l/min might be a bit much for my two little misting units , so it is possible that I need to add 2-3 more or just some copper to get some more volume trough it.
    here is somebody running a 65-120l/min system:
    https://www.youtube.com/watch?v=_X9TPBCdGyo
    Thank you for the recommendation. I will defiantly try it.
    Lives in Marple Stockport, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    These look like the same at a third of the price.
    http://www.banggood.com/Mist-Coolant...-p-979642.html
    Yeah I know. I just wanted to have it before the weekend.
    The chips being cold is not a good thing. They should be so hot they hurt when they hit your skin and the part should be cool...
    my legs are witness to that ...
    Welcome back Dean!
    Thanks Clive,
    i have browsed and browsed but have not seen these
    Quote Originally Posted by DuffelBuffelWuffel View Post
    Then make something provisional. By the way a quiet airbrush compressor like mine 17l/min is enough when using the proper nozzle and making fine mist.
    Much prefer mixing air with coolant as a cup of coolant could provide cutting all day long
    here is my system:
    On first video you could see the system and the damned mist when too much flow. Watch HD quality ant see how the light shows the mist in the air. What i am saying is it should not be like that cause after 5 min you could hardly breathe in the workshop.
    On second video is properly tuned and spraying just the minimum. The air when thin is so strong that will blow crap from 20mm cutter from 20cm distance and clean properly before the cut . Plus no problem breathing in the workshop
    Welcome back Dean!
    I Never left Boyan.! . . Was more unjust put in the naughty corner.!
    The other voice in that video sounds like a Yorkshire Man.?
  1. Acrylic Cutting Help
    By Tenson in forum Machine Discussion
    Last Post: 08-11-2016, 08:15 PM
  2. Cutting Ply/MDF
    By Leadhead in forum Wood Finishing Tips & Tricks
    Last Post: 02-10-2013, 01:59 PM
  3. Cutting Perspex?
    By Shinobiwan in forum Machine Discussion
    Last Post: 19-02-2013, 09:25 PM
  4. Cutting Fluid
    By Web Goblin in forum Swarf & Chip Management
    Last Post: 12-01-2013, 09:31 PM
  5. The Journey begins.. new to me.. my first CNC - Black Cat
    By Fivetide in forum Milling Machines, Builds & Conversions
    Last Post: 22-10-2012, 05:48 PM
