Thread: Stepper problem
  1. #14
    Quote Originally Posted by eurikain View Post
    EDIT: go to zero function works fine. I'm guessing the bob is fine... may be it's the drivers :/ Oh boy... I think I'm just going to buy a new PSU, new drives, and get a nema23 8 leads to match the others I got...
    NO Don't do that.!!!!. . . . . . The Drives, BOB, have NO control over Mach3 what so ever they are effectively UNDER MACH3's control and do exactly has they are told.
    So if you are saying the GOTO Zero makes the motors work fine then you have Mach3 setup wrong. How I'm not so sure without seeing the Mach3 XML
    So either post pics of your Mach setup screens or Post the XML file your using and I can look at it directly. You'll find it in the Mach3 folder under the same name has the profile your using. ie: MachMill or if Custom profile then name you choose. (You may have to Zip it up to post or Email me directly)
  1. Removing stepper motor problem from sherline mill
    By Neeps in forum Sherline Mills
    Last Post: 12-04-2015, 12:09 AM
  2. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  3. Stepper motors - problem
    By dudz in forum Stepper & Servo Motors
    Last Post: 13-02-2013, 07:07 PM
  4. Closed Loop Stepper Compared with Open Loop Stepper
    By Leadshine-Erci in forum Stepper & Servo Motors
    Last Post: 25-05-2012, 08:11 AM
  5. Stepper shaft size and pulley bore size problem
