Thread: Stepper problem
12-09-2015 #11
Alright, I'm back after about an hour and a half of testing. Here is what I did:
- Test the DB25 cable. All pins are through, no cross wires, and they work fine.
- Wire only one motor, in parallel, with 1/8mcs and 2.7A (as close as I can get to 2.8).
same problem. Same problem as before. Note that when not moving, the motors make weird sounds..., like a constant little quiet electrical noise, hard to describe. - Tried switching DIR and/or STEP active low setting. No change.
Here is what I haven't tried yet and will try tomorrow if you think it's worth it:
- pins 4 and 8 in all four possible positions (00, 01, 10, 11).
- switch one motor for the other (if same problem, it's not the motors, it's higher in the chain)
- switch one driver for the other (if same problem, it's the board that's broken)
- try another computer, who knows, the only thing I have changed since 2010 is this old computer. But it works fine, so I doubt it comes from there, but with those old guys, you never know.
So, if it's not the cable, not the PSU (already tested), not the motors, and not the drives, it's definitely the board.
What do you guys think ?Last edited by eurikain; 12-09-2015 at 12:59 PM.
Removing stepper motor problem from sherline mill
By Neeps in forum Sherline MillsReplies: 1Last Post: 12-04-2015, 12:09 AM -
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
Stepper motors - problem
By dudz in forum Stepper & Servo MotorsReplies: 7Last Post: 13-02-2013, 07:07 PM -
Closed Loop Stepper Compared with Open Loop Stepper
By Leadshine-Erci in forum Stepper & Servo MotorsReplies: 0Last Post: 25-05-2012, 08:11 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM
