Thread: Thinking about new CAD / CAM
Hi, Alphacam is a Cad/cCam program. You can design/draw, select cutter diameter, put on cutter paths, determine if you want to use alphacam offsets (I do) or let the G code do the offsets, select which side (or centre) of the lines to cut and which direction (climb or conventional), and alphacam will produce all the G codes. I am self taught and tried various progams, but think alphcam is far better than anything else I looked at. You can get alphacam for milling, but It is really more or less the same as the router program and I do in fact do some engraving drawings for a friend to produce the work on his mill. I am running an older version (v7) which luckily came with a machine that I bought, but it does everything that I ever need. I think the newer versions are probably more suited if you intend to do 3d work. If you wish to know more just phone or PM me. If you fancy a trip to lincolnshire you are welcome to come and play. G.
Thinking of buying one of these little things
By Hopey in forum Marketplace DiscussionReplies: 27Last Post: 19-05-2015, 10:44 PM -
Thinking of building a 3d printer.
By Jester in forum 3D Printing MachinesReplies: 0Last Post: 24-04-2015, 08:23 PM -
Thinking of buying/building machine for PCB milling
By njh in forum Marketplace DiscussionReplies: 32Last Post: 11-10-2013, 07:35 PM -
I'm thinking of bidding on a lathe , what do you think it is worth ?
By Fivetide in forum Marketplace DiscussionReplies: 17Last Post: 22-09-2012, 10:50 PM
