Thread: Easy Servo Drive?
14-09-2015 #8
Thanks for your replies.
Yes I am using the parallel port of a Sony Vaio Pentium 4 laptop. One thing I notice is that I get an occasional delay when jogging if the wi-fi is active. So I disable it when running.
Motors are 4nm nema 24. One pair for the main gantry (y axis) is driven from 80V and the x axis and z axis are driven from 50V. I thought the lighter weight would need less voltage but I think I probably made a mistake there as I suspect voltage directly affects motor top speed, while current affects torque? In which case my x axis will not be able to reach such a high RPM as the Y axis even though it has less weight to move.
I made a video just now. I must admit there are no problems with it in this case, lol! But I think it shows my point that the direction changes are fast at the center of the circle. This was at 2000mm/min. Circles do seem less round at higher speed and more round at lower speed. In this project I need to cut some 6mm holes and use a 3mm cutter, so the gantry will need to make very small adjustments and fast if the feedrate is high.
Anyway here it is, be gentle!
https://youtu.be/3mmX7BZWEjQ
Build Log: Servo Drive and VFD with vector control
By Jonathan in forum Electronic Project BuildingReplies: 17Last Post: 05-04-2015, 07:58 PM -
eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
By dazza in forum Items On eBay UKReplies: 0Last Post: 29-01-2015, 08:55 AM -
FOR SALE: 160v dc servo drive
By dazza in forum Items For SaleReplies: 0Last Post: 27-01-2015, 03:16 PM -
Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
By george uk in forum Motor Drivers & ControllersReplies: 20Last Post: 23-06-2014, 08:38 PM -
Servo drive problems
By Tomnewry in forum Motor Drivers & ControllersReplies: 15Last Post: 27-03-2013, 11:30 PM
