    My understanding of the operation of the drivers is that the direction pulse should overlap the step pulse at both ends, so whether direction is set one way or the other, High Low, 0v 5v whatever it should be in a settled state before the step pulse, then whether it is a positive going pulse or negative one, both the leading and trailing edges are within the direction state. I would imagine that if different protocols are used for step and direction then results would be unpredictable. As would happen when the timing of pulses is in error, then direction would not be properly set. - Hence missing steps.
    JAZZ - correct me if I am being Naive
    It's more to do with the Controller issuing the step pulse on the rising edge and the drive set to process it on the falling edge there becomes a timing issue so when a direction change occurs the step is in front of the Dir and a step or MS is lost on each change of direction.
    Having the wires on the drive wrong way around will also cause this. So Step + being connected to Step- on BOB. Also a BOB with slow Opto's could cause this but seen has the OP tried direct to drives I reckon not.!
    Emil,
    is this happening only to the Y axis?
    And I didn't see what drivers you are using.
    P.S. Saw the drivers in the first post.
    I think that is what I said i.e direction not settled before step.
    I didn't read it that way at first but reading again then yes same thing really.!! Time is shortened and next signal comes along before gets chance to complete last thing so something gets dropped at each direction change.! . . . . . I've eaten since then so my brains fired up again. . Lol
    Hello,
    THANK YOU for all of You.
    Problem is not resolved ... :(
    Yesterday i tried with LinuxCNC live DVD . 2.7.
    It is easy to try but the problem is the same !
    I moved only one ( Y ) axe because I want to fix the problem.
    I moved only in one direction .... from Y = 0 to Y = 600 ....
    When I moved Y ... after 200 mm ...300 mm I am receiving that motor knock ...
    In Linuxcnc - the same situation ... I tried many configurations .... for STEP pulses, driver setup ( I mean microstepping modes ... )
    A little bit better on slow speeds ..... and 400 steps per / rev .... but that is not good idea ..
    I have to check LPT voltage .. Also will try to drive the drivers by arduino .. to change speed and to prove driver quality ...
    Any ideas are welcome ....
    Thank you in advance,
    Emil
    Well first of all you seem to be jumping all over the place and not concentrating on trying to sort the problem out in a logical way. It is no use just trying random changes. So take it one step at a time giving clear and concise feedback.
    Some good pictures of the machine would help, are you using ball screws or screwed rod etc? You have already been asked to check the pp voltage out put. ie is it 3.3V or 5V but you have not answered. This might just be a simple pp and bob problem.
    Sorry to be a bit harsh. ..Clive
    Get an external motion controller. The parallel ports on Acer and Asus motherboards are not great, I have tried both of them and know. If you do not want to afford a motion controller, get a second PCI parallel port and see what you get but chances are you will still be having issues.
    Regards
    George
    https://emvioeng.com
    Problem solved. :) Thank you for all your help.
    The PC LPT port generate strange pulses .... from 4000 ns to 300 000 ns.... ( based on linuxcnc tests .. )
    Why I not saw the problem ..
    I tested all the electronics with my another PC ... ( also with the same problem .... but a little bit better !!! ), I used another PC with CNC machine for manu years, but just for some small cuts .. with perfect shape ... )
    So, I suppose my first PC is OK .... with both PC s .. the problem exists .... so the problem is in the electronics ....
    But when I tested it with NE555 generator .. motors are fine !!! So ... I became almost with no idea what to do ..
    I grounded all, used 74HCT245 ... 6N137 ... to change the logic voltage levels .... and finally on the last started the linuxcnc
    for N-th time and saw strange situation ....
    After start i have 4000 ns step period ... and after a while ... 1 second ... it increased to 300 000 ns.....
    after reset statistics button .... the same situation ...
    Mach3 doesn't see the wrong signals .... message is "System excellent" !!! :(
    I didn't investigate to check signals by scope in time period ... I have no time for that ...
    So, please fine attached first cut picture - 4 mm carbide tool in wood ..... Sorry I am not woodmaker ... it is just a test
    Have a nice day to all of you,
    Emil
ID:	16176   Click image for larger version.
    Please do not be offended by this:
    You are wasting your time the parallel port! You should seriously consider buying a motion control board like we have all suggested previously.
  1. New machine bogging down / missing steps
    By James123 in forum Gantry/Router Machines & Building
    Last Post: 19-12-2014, 12:02 AM
  2. clunks / missing steps - DM856 and single pulse operation
    By dsc in forum Motor Drivers & Controllers
    Last Post: 09-12-2013, 02:22 PM
  3. mach3, steps & microstepping
    By martin54 in forum Artsoft Mach (3 & 4)
    Last Post: 10-04-2013, 08:00 PM
  4. Strange problem, possibly missing steps?
    By Philly in forum Chinese Machines
    Last Post: 26-10-2012, 06:36 PM
  5. Missing Steps + Stalling X-axis
    By danielbriggs in forum Linear & Rotary Motion
    Last Post: 02-09-2010, 02:59 PM
