    I have stiffened up the X-axis ballscrew nut mounting by increasing material of bracket to 30mm, increasing cover plate to 10mm and inserting a 20mm triangular support.
    I feel somewhat uncertain with respect to using a single motor and belt setup for the X-axis. I remember reading that the Nema 34 motor should normally be avoided because acceleration is much slower than the 23. So do the advantages (better alignment, single motor) make up for the drawbacks (lower acceleration, long complicated belt)?
    Maybe a long belt could just go below the top cantilevers (and the bed) by using some extra idler pulleys?
Name:	X-axis screw nut mounting.jpg
ID:	16086   Click image for larger version.
  1. BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and Planes
    By njhussey in forum DIY Router Build Logs
    Last Post: 13-04-2020, 05:03 PM
  2. Aluminum router build - Could use some input
    By Tumblebeer in forum Gantry/Router Machines & Building
    Last Post: 01-09-2014, 09:48 PM
  3. My new, and first build....comments greatfully received
  4. Help appreciated
    By joncdrl in forum Milling Machines, Builds & Conversions
    Last Post: 17-09-2012, 08:34 PM
