19-09-2015 #27
Don't really need to do it like that. You need limit on X and Y on furthest away point only. For the other end the limit switch function can be shared with the home switch ( so only one near side limit / home switch needed per axis)
That makes 5 in total. You can add a Z lower limit if you want but not everyone does that.
As you can gather from that your home position is then in the nearest corner (0,0) on a graph paper not the middle. All movement and cutting is done at positive X and Y coordinates and since Z zero is at the top home then cutting is done in the negative Z
BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and Planes
By njhussey in forum DIY Router Build LogsReplies: 817Last Post: 13-04-2020, 05:03 PM -
Aluminum router build - Could use some input
By Tumblebeer in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 01-09-2014, 09:48 PM -
Help appreciated
By joncdrl in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 17-09-2012, 08:34 PM
