This is because they use a target at both ends ie the switch will travel with the gantry and so will hit the target at the end of travel in either direction.If we agree that the purpose of limit switches is safety and prevents the machine from exceeding its working area - why then is it not required to have limit switches in both ends of each of the axes? (ok Z is a little different).
Re point 3 It is the homing that give the ref points for the soft limits.
re point 4 After you have homed the Z you then move Z down to a ref point (say top of work piece) and then Zero it on the dro so now the machine or should I say the controller knows where zero is and can work out the depth of cut...Clive
BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and Planes
By njhussey in forum DIY Router Build LogsReplies: 817Last Post: 13-04-2020, 05:03 PM -
Aluminum router build - Could use some input
By Tumblebeer in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 01-09-2014, 09:48 PM -
Help appreciated
By joncdrl in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 17-09-2012, 08:34 PM
