Page 2 of 9 FirstFirst 1234 ... LastLast
    Quote Originally Posted by Tom J View Post
    I will try both spindles, only problem is that water cooled is heavier what cause the CoG move forward and is not in middle of sliding blocks on the gantry like is now with Kress.
    The slight change in CoG Won't make a Jot of difference to how the machine cuts but the WC spindle will make a big difference because it's far more ridged than the kress.!
    Coming along nice looking forward to seeing it working. ..
    Decided to use 1.5kw water cooled one after compared noise level with Kress - thanks Jazzcnc.
    Here is the base frame - profile 50x25x2
Name:	2015-09-21 19.13.35.jpg
ID:	16221   Click image for larger version.
Name:	2015-09-21 21.02.23.jpg
ID:	16222   Click image for larger version.
Name:	2015-09-21 19.51.00.jpg
    looking good
    thats quite a thin section ... 2mm , are you going to fill it ?
    Its actually 2.5mm thick, still thin, table itself is rigid enough. Gantry will have 50x5 to joint both legs, so should be no flex. In addition I use 5mm base for mounting all gantry blocks THK15. Will upload some photos after welding. Gantry is complicated as has to be adjusted to match the distance between rails on the bad. I will machine/plane X bases before welding them to top part (X mounting profiles). After all will be final machine to keep straight angle between table and Y plane and between base for blocks and Y plane - will do pictures as is confusing enough:)
  5. #15
ID:	16357Click image for larger version.
ID:	16358Click image for larger version.
ID:	16351Click image for larger version.
ID:	16352Click image for larger version.
  6. #16
    Base frame - surface planing (2.5" milling head - 63,5mm)
ID:	16354Click image for larger version.
ID:	16355Click image for larger version.
  7. #17
    Looking very nice Tom thanks for sharing, keep up the good work!
    .Me
ID:	16476Click image for larger version.
ID:	16477Click image for larger version.
    Drilling and taping M3 holes for 15mm rails
  9. #19
ID:	16479Click image for larger version.
ID:	16480Click image for larger version.
    Drilling holes - M3x16mm socket bolts. They tall enough to use entire thread depth and goes inside 25mm wide profile. There will be only 4mm hole left outside to insert the allen key:)
  10. #20
ID:	16482Click image for larger version.
    Errors are inevitable - forgot to cut the slot for the belt - grrr.
    Had to grind and mill 20mm slot - wasted my precious time.
  1. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  2. 5 axis desktop machine Kickstarter
    By 5AXISMAKER in forum Machine Discussion
    Last Post: 24-09-2014, 08:41 PM
  3. Desktop size build to learn on - PCB routing / small MDF work.
    By dynamis_dk in forum Gantry/Router Machines & Building
    Last Post: 26-02-2014, 11:50 PM
  4. FOR SALE: Strong steel welded base with ground flat surface.
    By black5f in forum Items For Sale
    Last Post: 14-01-2012, 07:20 PM
  5. Homemade desktop CNC - cutting 0.8mm mild steel out the question?
    Last Post: 16-04-2010, 09:37 AM
