ID:	16485Click image for larger version.
ID:	16486Click image for larger version.
    Frame almost done.
    Y motor bracket need to be welded in place
    Detecting plate for Home and Limit - this will have slots, so can be adjusted accordingly - should be done before was welded - now need to buy angle drill. I should finish design to last bolt first before starting fabrication - always do the same mistake - just not patient enough.
  1. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  2. 5 axis desktop machine Kickstarter
    By 5AXISMAKER in forum Machine Discussion
    Last Post: 24-09-2014, 08:41 PM
  3. Desktop size build to learn on - PCB routing / small MDF work.
    By dynamis_dk in forum Gantry/Router Machines & Building
    Last Post: 26-02-2014, 11:50 PM
  4. FOR SALE: Strong steel welded base with ground flat surface.
    By black5f in forum Items For Sale
    Last Post: 14-01-2012, 07:20 PM
  5. Homemade desktop CNC - cutting 0.8mm mild steel out the question?
    Last Post: 16-04-2010, 09:37 AM
