24-11-2015 #28
Ok. Jazz
I know what you mean by using one sensor:
So far I use 2 sensors, one is limit +, other is Home and limit- all in one, connected like that:
I think this is your option#3 " uses 2 inputs and 2 types of switch. NC wired in series for limits on one input. NO wired in parallel for Homes on other input"
I was wonder how you get away with having only one sensor, must use soft limits in Mach for safety. I've seen 3 sensors solution: limit+ limit- and home in one axis, but I think is not needed.
Correct me pls. if we I am wrong.
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
5 axis desktop machine Kickstarter
By 5AXISMAKER in forum Machine DiscussionReplies: 6Last Post: 24-09-2014, 08:41 PM -
Desktop size build to learn on - PCB routing / small MDF work.
By dynamis_dk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 26-02-2014, 11:50 PM -
FOR SALE: Strong steel welded base with ground flat surface.
By black5f in forum Items For SaleReplies: 0Last Post: 14-01-2012, 07:20 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM
