06-10-2015 #12
Its actually 2.5mm thick, still thin, table itself is rigid enough. Gantry will have 50x5 to joint both legs, so should be no flex. In addition I use 5mm base for mounting all gantry blocks THK15. Will upload some photos after welding. Gantry is complicated as has to be adjusted to match the distance between rails on the bad. I will machine/plane X bases before welding them to top part (X mounting profiles). After all will be final machine to keep straight angle between table and Y plane and between base for blocks and Y plane - will do pictures as is confusing enough:)
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
5 axis desktop machine Kickstarter
By 5AXISMAKER in forum Machine DiscussionReplies: 6Last Post: 24-09-2014, 08:41 PM -
Desktop size build to learn on - PCB routing / small MDF work.
By dynamis_dk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 26-02-2014, 11:50 PM -
FOR SALE: Strong steel welded base with ground flat surface.
By black5f in forum Items For SaleReplies: 0Last Post: 14-01-2012, 07:20 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM
