Page 3 of 9 FirstFirst 12345 ... LastLast
  1. #21
ID:	16483Click image for larger version.
    Base for legs: 2mm profile (2.5 before planing) 5mm plate plus m8 nut, so total of 15mm thread depth for vibro-damping stands.
  2. #22
ID:	16485Click image for larger version.
ID:	16486Click image for larger version.
    Frame almost done.
    Y motor bracket need to be welded in place
    Detecting plate for Home and Limit - this will have slots, so can be adjusted accordingly - should be done before was welded - now need to buy angle drill. I should finish design to last bolt first before starting fabrication - always do the same mistake - just not patient enough.
  3. #23
    Had to shortened the RM1605 ballscrew by 14mm.
ID:	16489Click image for larger version.
ID:	16490Click image for larger version.
ID:	16491Click image for larger version.
    My tip for turning exact diameter is to leave 0.1mm and use sand paper on the end to get nice fit to bearings.
  4. #24
    Looking good Tom keep it up can't wait to see it Rattle n Roll. .
  6. #25
    Planing base for ballscrew - base is 60x5 mild still (as we know is far from flat, unlike cold rolled - bright steel)
    As always got some distortion after welding.
Name:	2015-11-16 16.56.34.jpg
ID:	16541Click image for larger version.
Name:	2015-11-16 17.19.58.jpg
ID:	16542Click image for larger version.
Name:	2015-11-16 19.15.17.jpg
ID:	16543Click image for larger version.
ID:	16544Click image for larger version.
ID:	16545Click image for larger version.
  7. The Following User Says Thank You to Tom J For This Useful Post:
  8. #26
    Updated design - new colour, few minor changes in Z plate
Name:	Assem ballscrew9.JPG
ID:	16595Click image for larger version.
Name:	Assem ballscrew10.JPG
ID:	16596Click image for larger version.
Name:	Assem ballscrew11.JPG
ID:	16597Click image for larger version.
Name:	Assem ballscrew12.JPG
ID:	16598Click image for larger version.
Name:	Assem ballscrew13.JPG
ID:	16599Click image for larger version.
Name:	Assem ballscrew14.JPG
ID:	16600Click image for larger version.
Name:	Assem ballscrew15.JPG
ID:	16601Click image for larger version.
Name:	Assem ballscrew16.JPG
    Welding the gantry - was waiting for another precision angle from Amazon - Happy with the result 0.5 mm off i checked against one side - spot on from other side. When all will be welded together (base for rails, ribs, etc) than will machine the base to have straight angle. I will leave the rails on the block, as this will be reference surface to the angle plate when fix to the mill - confusing now, but will show the picture soon.
    Meantime - how I achieved accuracy before welding - spot how I use the straight angles (Gantry legs, than against table and Base for X axle) All surfaces has been planed each time I weld something - this was my error, should weld everything first than machine to avoid distortion.
ID:	16603Click image for larger version.
ID:	16604Click image for larger version.
  9. #27
    Tom I spotted 2x Fixed Prox switches on the Gantry. Do it other way around and use just one traveling switch with Fixed Targets, less switches less wiring same result.
    Looking Good. . .
  10. #28
    Jazz, other side is reserved for cable carrier, so switch(es) has to be near the motor. Did you noticed that bed frame has slightly more room opposite the motor (just enough for radius/bend of my cable carrier
Name:	chain location.jpg
    I always was using two sensors - Limit and Home with Mach3 - connected similar to that:
    can you explain how to use one switch (NC)? Wiring diagram would be ideal:)
    I know how to daisychained together - but this is limit side, how to wire them to use Home?
    Each black signal wire to input X,Y and Z?
  11. #29
    Quote Originally Posted by Tom J View Post
    Ok well maybe we are at odd's here.? It looked like 2 switches for Limits and I was meaning just have one switch that traveled.
    But call it option #1 if your wanting to Share one Switch for Limits and Home then you can do that but with NC switches each Axis will need a Input. So 3x switches and 3 x Inputs.
    Option #2 You can use NO switches then you can have all Limits and Homes on 1 input and wire them in parallel. So 3 x switches and 1x input.
    What you lose with the later is the Safety of NC switch but you have more inputs to play with if limited.
    Other option #3 uses 2 inputs and 2 types of switch. NC wired in series for limits on one input. NO wired in parallel for Homes on other input.
    This gives Safest option because Limits can be set to be monitored while Homing.
    #1 Shared Home and Limit on 1 Input with NC Switch is easy. Just wire each Axis switch to a Input. Then in Mach3 ports&pins Inputs set the limits and home input for that Axis to same Pin number. Set Both to go Active Low. Then go into General config and Turnoff(uncheck) HomeSW safety and thats it.
    Now when Mach homes it ignores Limits.
    #2 Setup for NO is just the same but All Axis share same pin number for Limits and Home. Then set to go Active High. Rest is just the same.
    #3 Should be obvious really.!! Limits in Input 1 set active Low. Homes in Input 2 set Active High. Then turn ON Home SW Safety.
    Can do a diagram if you let me know which you prefer.
  12. The Following User Says Thank You to JAZZCNC For This Useful Post:
  13. #30
    Ok. Jazz
    I know what you mean by using one sensor:
    So far I use 2 sensors, one is limit +, other is Home and limit- all in one, connected like that:
    I think this is your option#3 " uses 2 inputs and 2 types of switch. NC wired in series for limits on one input. NO wired in parallel for Homes on other input"
    I was wonder how you get away with having only one sensor, must use soft limits in Mach for safety. I've seen 3 sensors solution: limit+ limit- and home in one axis, but I think is not needed.
    Correct me pls. if we I am wrong.
  1. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  2. 5 axis desktop machine Kickstarter
    By 5AXISMAKER in forum Machine Discussion
    Last Post: 24-09-2014, 08:41 PM
  3. Desktop size build to learn on - PCB routing / small MDF work.
    By dynamis_dk in forum Gantry/Router Machines & Building
    Last Post: 26-02-2014, 11:50 PM
  4. FOR SALE: Strong steel welded base with ground flat surface.
    By black5f in forum Items For Sale
    Last Post: 14-01-2012, 07:20 PM
  5. Homemade desktop CNC - cutting 0.8mm mild steel out the question?
    Last Post: 16-04-2010, 09:37 AM
