24-11-2015 #24
Updated design - new colour, few minor changes in Z plate
Welding the gantry - was waiting for another precision angle from Amazon - Happy with the result 0.5 mm off i checked against one side - spot on from other side. When all will be welded together (base for rails, ribs, etc) than will machine the base to have straight angle. I will leave the rails on the block, as this will be reference surface to the angle plate when fix to the mill - confusing now, but will show the picture soon.
Meantime - how I achieved accuracy before welding - spot how I use the straight angles (Gantry legs, than against table and Base for X axle) All surfaces has been planed each time I weld something - this was my error, should weld everything first than machine to avoid distortion.
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
5 axis desktop machine Kickstarter
By 5AXISMAKER in forum Machine DiscussionReplies: 6Last Post: 24-09-2014, 08:41 PM -
Desktop size build to learn on - PCB routing / small MDF work.
By dynamis_dk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 26-02-2014, 11:50 PM -
FOR SALE: Strong steel welded base with ground flat surface.
By black5f in forum Items For SaleReplies: 0Last Post: 14-01-2012, 07:20 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM
