25-11-2015 #29
Yes if you turn off HomeSW Safety in General Config.
When using slaved motors Mach De-couples each motor turning back into two separate axis while homing happens which means the motors work independantly but move together in sync towards the home switches. When first switch is tripped that axis motor stops and backs off the switch while the other keeps going then does the same.
In practise provided your Gantry is square and the switches positioned correctly this appears to happen has one action. If your gantry is really out of square then you can position the switches to force it square.
When Both Motors have homed then Mach Couples the Axis again back into one slaved axis.
This does mean that the Slaved Motor needs it's own Home switch on a Separate Input.Last edited by JAZZCNC; 25-11-2015 at 02:54 AM.
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
5 axis desktop machine Kickstarter
By 5AXISMAKER in forum Machine DiscussionReplies: 6Last Post: 24-09-2014, 08:41 PM -
Desktop size build to learn on - PCB routing / small MDF work.
By dynamis_dk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 26-02-2014, 11:50 PM -
FOR SALE: Strong steel welded base with ground flat surface.
By black5f in forum Items For SaleReplies: 0Last Post: 14-01-2012, 07:20 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM
