    Time for Y axis drive. Gantry legs will be connected under the bed by flat steel 50x5mm.
    I will use only one ballscrew for moving the gantry as this is desktop size machine (travel distance from left to right is 300mm, forward and backwards only 220mm).
    I sacrificed 80mm of travel on Y for bigger distance between bearing block - stiffness won.
    Had to fabricate Ballscrew nut bracket today - picture later.
    Than I can center the ballscrew mount (front and back) so there is no tension on screw when turns backwards/forward.
    A lot of steps in fabrication depends on previous - all related. Can not jump forward without doing something which have to be done first. Sometimes I loose the plot and do something what shouldn't be doing at that time like - pick up for sensors:
ID:	16842Click image for larger version.
    or sensor bracket/s
    It's the little details that eat the time but they also make the difference between just OK machine and great machine. This is well on way to being great machine so keep it up mate and no rushing.
    Thanks Jazz, SolidWorks helps a lot, I print the template before I drill any hole and cat any shape, use automatic puncher to be precise. Can not wait to the end.
  4. The Following User Says Thank You to Tom J For This Useful Post:
  5. #4
    Quote Originally Posted by Tom J View Post
    Yep I do the same paper and Spray mount it's priceless.!. . I even do the same On cnc machine some times when cutting parts out of large sheet just to be sure they'll fit and not waste material or clash with clamps etc. I then write Tap sizes etc for holes on sheet to remove chances of error etc.
  7. #5
    Yep I do the same paper and Spray mount it's priceless.!. . I even do the same On CNC machine some times when cutting parts out of large sheet just to be sure they'll fit and not waste material or clash with clamps etc. I then write Tap sizes etc. for holes on sheet to remove chances of error etc.
    Thanks chaps, for a desk based worker like me those are brilliant tips! I hadn't realised the benefits of an automatic puncher and I hadn't thought of printing a template. Now to see if the free version of Sketch-Up can print to scale? And find out what sort of spray mount to use?
    "An automatic center punch is a hand tool used to produce a dimple in a workpiece (for example, a piece of metal). It performs the same function as an ordinary center punch but without the need for a hammer. When pressed against the workpiece, it stores energy in a spring, eventually releasing it as an impulse that drives the punch, producing the dimple. The impulse provided to the point of the punch is quite repeatable, allowing for uniform impressions to be made." https://en.wikipedia.org/wiki/Automatic_center_punch
  8. #6
ID:	16887Click image for larger version.
    Got problem with proxy sensor in X axis - not too much room to fit.
    Any recommendation for flat body type and 1-2mm range PNP NC like that:
  9. #7
    I find the Round type better has they give more adjustment. Use traveling switch then you'll only need one per axis and it can travel with Z axis facing down there's plenty of room on back of there for a bracket and loads of room on top of gantry for targets.?
  10. #8
    Got some old alu plate - enough for table
    Bed profile was 2.5mm thick before. Now after surface planing is a bit less so I used thread rivet to fit the table top.
ID:	17584M5 countersink bolts
ID:	17585 One Y sensor for Home and Limit (PNP NC)
  1. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  2. 5 axis desktop machine Kickstarter
    By 5AXISMAKER in forum Machine Discussion
    Last Post: 24-09-2014, 08:41 PM
  3. Desktop size build to learn on - PCB routing / small MDF work.
    By dynamis_dk in forum Gantry/Router Machines & Building
    Last Post: 26-02-2014, 11:50 PM
  4. FOR SALE: Strong steel welded base with ground flat surface.
    By black5f in forum Items For Sale
    Last Post: 14-01-2012, 07:20 PM
  5. Homemade desktop CNC - cutting 0.8mm mild steel out the question?
    Last Post: 16-04-2010, 09:37 AM
