22-09-2015 #12
Ok - so this is the reply they sent me. Confirmation its to be avoided?
"Hi Josh
Thanks for your message .
This is a full set machine, with water cooling pump & hand controller, but if you need it to work perfect, you need to connect it with a PC.
It is controlled by Mach3 software(we have a software CD to go with the machine, on the CD, there is a demon version Mach3).
When you got the machine, you can install the software on your desktop PC(Window XP/2000) by LPT port.
There is a brief manual on the CD, you can set up the software following the manual guide, when you have this work done, the machine can run normally,
but if you need to make it work for your need, you need to do some CNC drawing & programming on other CNC software first,
then load the program on Mach3 so that you can make the machine to do your own work accordingly.
We have 1pcs 3mm bit & 1pcs 6mm bit included in the package for you, if you need some other machining bits, you got to prepare them by yourself.
This machine can work on metals like Aluminum, brass, stainless steel etc, here are some video for your reference:
http://i.youku.com/u/id_UMTM0MDQxOTc2OA==
The item will be shipped via DHL ,usually you will receive the item 12-15 business day
The business day is not include saturday and sunday .
We do appreciate your understanding and time.
If you have any questions,feel free to contact us,we are always here to serve you.
Looking forward to your reply
Best regards
Candy"
Video link - http://v.youku.com/v_show/id_XNzA0ODI0MzAw.html?from=y1.7-1.2
FOR SALE: CNC 4 axis Foam Cutting Machine
By Am1707 in forum Items For SaleReplies: 1Last Post: 25-06-2015, 01:43 PM -
New machine Z axis
By Web Goblin in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 09-06-2014, 06:08 AM -
CNC machine "Spanish" model . Advice and opinions needed!
By shapebusters in forum Machine DiscussionReplies: 17Last Post: 12-03-2014, 06:21 AM -
Your views and opinions on the Black Cat CNC Machine 600x900 please
By Rockeyes in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 31-05-2012, 05:21 PM -
Opinions sought on cheap desktop PCB milling machine
By ksangeelee in forum Milling Machines, Builds & ConversionsReplies: 55Last Post: 16-03-2012, 01:57 PM
