    I'm sorry but this is not cutting.!! . . . . I see scratching, rubbing and hear plenty of resonance but not much cutting going off.!!
    Agree, should have written "dissuasive "
    Best get a converted machine or see if exonomical to farm bits out
    https://emvioeng.com
    Same as I posted in the thread of the other guy:
    Buy FS4MG LANG and add one of those china 4th/ 5th axis.
    http://cnc-technik-mueller.de/fs4mg-...lgussmaschine/
    This + usbcnc (Eding) + leadshine closed loop stepper 2nm (ebay) + gdk80-12-24Z/1.2-2.2 spindle
    But be prepared that the end price is around ~6.5K euro without tax
    Fusion 360 as CAM software (3+2axis) "free"
    Also buy a haimer 3d probe , a bunch of 1/2/3 flute VHM mills for alu and a decent toolsetter + add limit switches to the machine + a decent vice (the Vertex VA4 fits nice on the bed)
    Now you home the machine -> inset the haimer probe -> it auto measures length and does compensation (G49) -> zero the stock
    Now run your code -> insert endimill -> auto measure length and G49 it (saves you so much time and makes your tolerances much better).
    Having a spindle that has ATC is even better ... but those are quite pricey.
    I have not done any steel yet , but I can't see why it is an issue (forgetting the spindle speed).
    They Also Have the FS3MG which is "made" for steel. The base price is quite a bit higher but still doable for a small business.
    Its perfectly possible to build, yourself, a machine for milling steel.
    99.9% of people who start, fail.
    I scratch-built a VMC.
    It went like this.. (as my wife reminds me..)
    A couple of weekends and some hundreds of €€...
    ((Router->Bridgeport M head-> ISO30 spindle)).
    15.000 work hours later, I am finishing the V3 iteration of what is now a commercial quality VMC.
    This is what it entails;
    32 mm ballscrews, 1200 mm working length
    Moving table, in steel, 1600x500 mm, 60 mm thick, 200 kg in mass (will double to 400 kg and 11 cm thick)
    35 mm linear rails and trucks
    ISO30 spindle (about 1300€, they are not that expensive)
    Brushless AC servos, 400W, 1.3 Nm continuous, 3.9 Nm peak
    125 kHz hardware controller for high pulse rates
    Current step size is 0.2-0.3 microns on each axis.
    Machine is 2.3 wide, 1.6 m tall, 2 m deep, approx 2000 kg in mass, all built in basic local tool steel "F1 calibrado".
    Table size is 1600x500, with 1200 x 1200 work area.
    Most people wont have the patience, time, space and ability to continue for so long, until you finish something like this.
    I am now a professional machine builder, with factory training from a major manufacturer (2 years ago).
    My own machine costs about 20k in components.
    Retrofitting an old manual metalworking mill is much easier and cheaper.
    A scratch built machine is much better (more work envelope for cost and volume, more rigid for the mass and size).
    Current machine rigidity is 17N/um, which is acceptable industrially.
    Goals are 10-70N/um rigidity according to industrial guides and textbooks on machine design.
    A good set of retrofit gear costs about 2500€ and up.
    Quote Originally Posted by hanermo2 View Post
    Ye and After spending ££££ trying.!!
    Hannu where are you buying Iso30 spindles from @1300euro.? Also what rpm bearings.? I presume your using a Servo to power it.? If so what size and RPM.
    Hows the Lathe upgrade coming along.? I'd like to see this working when it's finished so please post a video. Also the mill. .
    The ISO30 ATC spindle has a cost of 1300€ to me, with the sales tax paid, here in the EU.
    I import my own stuff, and can include extras in each lof, if someone wants some.
    These usually arrive about once per month.
    The spindle has 7000 rpm bearings, theoretically.
    Im not sure, actually, what I will use to power it.
    I will probable get a servo, and I will probably need to order it with the next lot of stuff.
    My bridgeport mill 3-phase motor works.
    I have a spare 2.2 kW VFD.
    A new motor (second hand) is very cheap.
    So, for maybe 100-150€ I can get a 2-3 kW motor, and I might do that to try.
    I dont have spare, large, servos, only 750 and 400W ones, atm, but this changes.
    I very much wish to do rigid tapping, and high-speed accelerations, ie servo.
    Yet, a 2-3 kW servo is about 1600€.
    The spindle should handle 5-7 kW, theoretically.
    My machine frame, hopefully, will do 3 kW.
    If it does, I will be Very Happy.
    Anything above 1 kW cutting power is fine, for me.
    The machine is very large re_frame, but I dont expect to do major metal removal. If I do start doing so, then a big servo is the first thing.
    The lathe upgrade is progressing !!
    Wenesday, first side plates, friday, last side plates, friday, the lockbar tap broke inside the spindle motor lockbar piece !
    Today, after getting new M8 tap, main drive lockbar is in place !
    This locks the spindle mount solidly in pace.
    Material is 20 mm thick tool steel plate, and 30x50x350 mm bars, 3 of.
    All on top of the lathe, where they belong.
    I learned this trick from Haas.
    When the motor is above the spindle, the heat does not go into the spindle and headstock.
    1.
    Now, to disassemble all the main spindle, new saddle, mounts and sideplates.
    Sand everything (dirty, noisy, heavy work. Yum. But goes fast, with a festool 1400W industrial hand sander).
    Primer.
    Leave to dry till monday ..
    2. or keep going, until x axis servo is in place.
    Maybe option (2)..
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 1 Week Ago Has a total post count of 1,654. Received thanks 115 times, giving thanks to others 71 times.
    Some pics or vids of this beast please?
    Chaz's Avatar
    Some pics / vids of this machine?
  1. FOR SALE: CNC 4 axis Foam Cutting Machine
    By Am1707 in forum Items For Sale
    Last Post: 25-06-2015, 01:43 PM
  2. New machine Z axis
    By Web Goblin in forum Gantry/Router Machines & Building
    Last Post: 09-06-2014, 06:08 AM
  3. CNC machine "Spanish" model . Advice and opinions needed!
    By shapebusters in forum Machine Discussion
    Last Post: 12-03-2014, 06:21 AM
  4. Your views and opinions on the Black Cat CNC Machine 600x900 please
    By Rockeyes in forum Milling Machines, Builds & Conversions
    Last Post: 31-05-2012, 05:21 PM
  5. Opinions sought on cheap desktop PCB milling machine
    By ksangeelee in forum Milling Machines, Builds & Conversions
    Last Post: 16-03-2012, 01:57 PM
