Sorry if I'm going to sound negative but the Denford won't be good for Aluminium and 3D.! . . Why.? . . . Because of the lack of spindle speed.
Aluminium in general needs faster spindle speeds than most mills can offer. Yes they will cut it no problem but feed rate will be slow and the surface finish not the best. This gets worse when your looking to do 3D work because often smaller Diameter tools are involved which require much higher spindle speeds.
So if your thinking mostly aluminium work and looking at mills then bare spindle speed in mind.
BUILD LOG: Steel Gantry Machine 1500x750x200
By toomast in forum DIY Router Build LogsReplies: 99Last Post: 02-03-2018, 06:27 PM -
polishing stainless steel machine
By Blackrat in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 17-08-2014, 04:46 PM -
Milling mild steel
By dudz in forum Machine DiscussionReplies: 33Last Post: 16-02-2014, 02:31 PM -
Milling Steel?
By Musht in forum Metalwork DiscussionReplies: 12Last Post: 02-12-2012, 08:00 PM -
Cutting 1.6mm mild steel with a CNC machine?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 01-05-2012, 09:56 PM
