Thread: BZT - A Poor Quality Machine
I will take a picture not of the inner electronics. I do not think it has this board
23-09-2015 #2
You could send your cnc.ini file to the designer:
http://www.edingcnc.com/contact.php
He might be able to tell whats wrong.
Or ask a question (in english) on this forum:
http://www.cnczone.nl/viewforum.php?f=39Last edited by DuffelBuffelWuffel; 23-09-2015 at 07:56 PM.
23-09-2015 #3
BZT have their own parameters that you copy to the CNC 4.01 folder when installing the software and the USB driver.
To reintall the firmware I assume you mean take out the board download latest version and write to board via USB?
23-09-2015 #4
yes
You do not have tu "use" their values , this is just a "simple" 3 axis cnc , it is not rocket science. It might be something in their settings file that might cause the explainable "stall".
Checking the stepper wires / other connections is also wise.
23-09-2015 #5
The wiring seems OK as it runs OK when started up fresh. The problem only happens a few mins after running
23-09-2015 #6
Yeah... I would contact bart eding on that subject .. this is quite weird
It also might it be that there is a bad connection and vibrations / current draw are causing the stall / step loss issue.
I would just check the resistance of the wires.Last edited by DuffelBuffelWuffel; 23-09-2015 at 08:06 PM.
23-09-2015 #7
Will do now.
Just taking the boards off first
Poor man's T-track
By D.C. in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 04-10-2019, 01:42 AM -
New member looking for advice on a good quality machine (brand)
By steve78 in forum Marketplace DiscussionReplies: 1Last Post: 16-08-2014, 09:25 PM -
Cut quality
By Web Goblin in forum Machine DiscussionReplies: 22Last Post: 06-02-2013, 07:45 PM -
Poor start to New Year
By russell in forum General ComputingReplies: 13Last Post: 04-01-2013, 02:24 PM
