Thread: New build stepper help
Ok well one thing I've seen before on cheap drives is the pulse edge only works one way so to speak and if the polarity is wrong then they do weird shit.!! So try changing the active low and see if it affects anything.!
Other than that then it's down to either wrong phase wiring, bad PP cable or Poor low power PP port or BOB.!! Have you measured the voltage coming out the PP and the BOB.?
Presume you have tried on different drive and motor to eliminate a bad one.!
22-09-2015 #2
Jazz - yes tried changing active low.
Will check phases, voltages and 5v supplies in the morning. Too pissed with it right now!!
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Closed Loop Stepper Compared with Open Loop Stepper
By Leadshine-Erci in forum Stepper & Servo MotorsReplies: 0Last Post: 25-05-2012, 08:11 AM
