Yes I know sad bastitch aren't I ?
Button on screen just under the DRO's marked Machine Coords, second from right. toggle between the two states, lights up red when in MC.But how for example, does Mach3 differentiate between the two?
The homing switch will only inhibit this IF your part is that big it's shape is the same size at the bed travels.When I import Gcode, the CNC moves the tool to act upon those coordinates in the G-Code - Mach3 doesn't ask "are these MCs or WCs?") ...therfore if, back to my example, I have a countour line running along X0, the tool will try & get 3mm past that (the diameter of the tool) , but the homing switch will inhibit that.
If for example your bed travel in X is say 300mm then the max part you can cut in theory with a 3mm cutter is 300 - 1.5 - 1.5 so 297mm.
In practice it would have to be a tad less because you may get switch bounce.
The two sets are always there but once set the MC can be switched back to WC and ignored, as stated before goto home or home all will travel to the home switches. Goto zero will go to your WC point.So how does CNC app differentiate between a home MC of 0,0 & then subsequently interpret / apply WC 0,0 to a different position?
I guess I'm trying to figure how you have two set of coordinates in practise!
This WC, MC is one of the stumbling blocks that catch beginners out the most. You can ignore the home switches and not set them if you don't want and just stay in WC and reset 0,0 to the corner of your work and keep changing this from job to job.
You can still have limit switches at both ends for safety, just no home switches allocated.
.John S -
13-06-2009 #2
Many thanks John,
I've been ignoring them until now...but I need replicability (in other words, I'm aiming towards a goal, where I can easily churn some simple identical parts out in short order).
Parking the replicability for a moment, I have a fairly imminent need to be able to mill a tiny pocket out of the end of some plastic threaded rod (I don't have a lathe) ..one way I've considered tackling this 'how to' problem is via a home switch. Basically, if I can start my spindle/tool from an exact known location everytime, then I could for example have the tool drill a whole in my cnc's base plate with the tool - self harming for CNCs! (actually probably some waste material clamped to the base plate!)....I can then tap thIS hole & insert/twiste my threaded rod into it...becaUse the cnc tool drilled the hole in the first place, it knows the exact centre...but the tool would need to start out from the same position each time (hence the home switch!).
It's got to the stage where I can see quite a use for starting the tool in a known position each & every time.
13-06-2009 #3
That can be done without home switches or anything.
Fasten your sacrificial block onto the bed, position the tool where you want the hole by guesswork / eyesight / ougie board etc Zero all the axis at this point in Mach by clicking the Zero x, Zero Y etc buttons at the side of the DRO's
Drill your hole with the cutter, move away, tap it, fit screw, press Goto Zero button, under the DRo's and it will return to where you drilled your hole every time.John S -
G540, homing switches and mach3
By marbles in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 02-06-2018, 02:55 PM -
Query - Zen Toolworks looky likey
By Plod in forum Marketplace DiscussionReplies: 9Last Post: 30-11-2013, 01:15 PM -
RFQ: Simple job cutting simple shapes out of camera lens cap
By RockandGrohl in forum Projects, Jobs & RequestsReplies: 15Last Post: 20-04-2013, 01:23 AM -
Homing switches & 'methods of working' (Mach3)
By HankMcSpank in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 19-10-2012, 12:54 AM -
Homing Switches
By m_c in forum General ElectronicsReplies: 3Last Post: 04-11-2010, 11:21 PM
