    (I must just be a reactionary old fart ).
    Rob,
    I don't think that's the case, everyone is best sticking with what they're happy with.
    Windows 7 simply gives access to several later generations of PC hardware,
    Regards,
    Nick
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 83 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    It also depends if it is 32bit or 64 bit syatem
    Given that parallel ports are not supported under 64 bit then external motion controllers would be the only option in 64 bit, Mach3 still works under 64 bit though
    - Nick
    Takes me back...
    C:\>debug
    -d40:0
    0040:0000 F8 03 00 00 00 00 00 00 - 78 03 00 00 00 0B 02
    -q
    C:\>
    Meaning one serial port at 03f8h and one parallel port at 0378h so if you wrote to 0378h your data would be on the pins in microseconds if not faster.
    Of course you were supposed to access it via the BIOS, not that that would slow it down much.
    It only really goes tits up when writing to 0378h causes an interrupt that will join the queue to sort the mess out at some nebulous time in the future.
  5. #15
    I also don't like Windows 8 and 10. My wife just got a Win 8 'Surface Pro' from work. I can't make heads nor tails of it on first use. I'm very comfortable with win 7 and predecessors.
  6. #16
    i2i's Avatar
    this p/port computer problem is not down to a specific model or make of computer. I have 8 dell computers that are exactly the same, four of them work, four of them don't. They all have the same setup and were completely wiped before installation of xp.
  7. #17
    It's about the parallel port spec, not PC model, Dell were known for swapping things on boards during the life of a model, if you got a replacement board under warranty it might or might not even support the OS install on the existing HDD.
  8. #18
    I never trusted Dell, they were chucked together as cheaply as possible in my opinion. Most of my machines I built myself, it's not rocket surgery.
  9. #19
    i2i's Avatar
    going back to the old days when dell first appeared they were the dogs bo**ocks, high quality intel based machines that set the standard. Nothing lasts.
  10. #20
    Reviewing this thread I am a tad curious, would using the UC100 bypass this issue with the PC's, I know it is a more expensive option compared to simply getting a PP card but I'm seeing a lot of good reviews about having one.
    I've been interested in buying a UC100 as an upgrade later on in the year and been trying to find a legit seller (as been only able to find cloned versions)
  1. Mach3
    By petesos in forum Artsoft Mach (3 & 4)
    Last Post: 23-10-2012, 10:18 PM
  2. Mach3 and LCD
    By dzero in forum General Electronics
    Last Post: 30-07-2012, 12:50 PM
  3. mach3 goes off the bed
    By swinds in forum Artsoft Mach (3 & 4)
    Last Post: 17-01-2012, 11:43 PM
  4. mach3
    By edgas10 in forum Artsoft Mach (3 & 4)
    Last Post: 27-04-2011, 11:18 PM
  5. MPG and Mach3
    By GeoffV in forum Artsoft Mach (3 & 4)
    Last Post: 08-10-2010, 05:56 PM
