    You all convinced me I am going to purchase the UC400 as like doddy said earlier its only a few pints in difference :D
    I got my PCI card in though in the meantime I was going to test the LPT port issue but I cant get the PCI port to link with Mach3 :/ my I/O is DC00 - DC07 so I am putting in 0xDC00 in the port settings under LPT1 (which I have named the PCI port as well. Is this right as there was no instructions that came with the card?
    Quote Originally Posted by Palletlad View Post
    It's the 300 that's a few quid more than the 400. But, I'm sure the 400 is suited to your needs. Not that I'm condoning your fix-by-replacement-until-it-works approach, but you know that already.
    ah this wasn't part of the replace to fix it, its simply an upgrade I was looking at from the get go. I brought a cheap pci card to see if its the lpt port causing issues, just need to configure it properly and then I should be able to use the machine.
    UC300 wont suit my requirements as it offers too much than what I will use it for but from £20 more from the UC100 I might as well get the UC400.
    The UC400ETH is a little more than a UC100, and a UC300ETH is a little more than a UC400ETH.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  1. Mach3
    By petesos in forum Artsoft Mach (3 & 4)
    Last Post: 23-10-2012, 10:18 PM
  2. Mach3 and LCD
    By dzero in forum General Electronics
    Last Post: 30-07-2012, 12:50 PM
  3. mach3 goes off the bed
    By swinds in forum Artsoft Mach (3 & 4)
    Last Post: 17-01-2012, 11:43 PM
  4. mach3
    By edgas10 in forum Artsoft Mach (3 & 4)
    Last Post: 27-04-2011, 11:18 PM
  5. MPG and Mach3
    By GeoffV in forum Artsoft Mach (3 & 4)
    Last Post: 08-10-2010, 05:56 PM
