05-10-2015 #5
I was thinking to gear it 10:18. I suppose I could find a different belt / pulley setup. This is the smallest I can find (easily) to go (10) using the stock setup.
This lowers the speed to almost half and should therefore provide almost double the torque. Its a pity that the removed Servo motors are a bit small, else they would be ideal, specifically with closed loop control. They also do 8K RPM, worth a look at all?
So Nearly there - Mach3 and VFD Spindle Speed.
By davegrennan in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 11-04-2015, 12:30 AM -
Use spindle torque to control feedrate?
By Jonathan in forum Tool & Tooling TechnologyReplies: 4Last Post: 02-05-2014, 10:37 AM -
Spindle torque required
By m_c in forum Spindles & Drive MotorsReplies: 2Last Post: 06-09-2012, 09:43 PM -
Spindle Speed Measurement
By clockmaker in forum Spindles & Drive MotorsReplies: 2Last Post: 04-12-2010, 11:38 PM -
High speed spindle
By leadinglights in forum Tool & Tooling TechnologyReplies: 0Last Post: 27-04-2010, 09:23 PM
