Thread: End mill question
15-06-2009 #2
If it's for Acrylic get a 2 flute cutter, they will be called end mills or slot drills.
2 flute is better as with soft materials you need as much room as possible to get rid of the chips as they are usually cut faster than harder ones.
Acrylic tends to melt if run too fast in speed and feed, coolant is ideal or at least a strong air blast to stop it melting.
HSS is better than carbide as you can get a sharper edge on HSS
In a worse case scenario it melts and then re welds itself back again behind the cutterJohn S -
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
NEW MEMBER: Re my question
By oldwoodworker in forum New Member IntroductionsReplies: 32Last Post: 20-09-2013, 09:07 PM -
question ...
By Wobblybootie in forum General DiscussionReplies: 6Last Post: 04-01-2010, 12:04 AM -
A question
By bodgeitandscarper in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 02-12-2009, 08:30 AM
