Thread: End mill question
23-09-2009 #4
What you describe is essentially a 'centre cutting endmill' which is basically a slotdrill. The main problem with cutting plastics is heat generation through cutting. You want to keep the heat in the cutter and not in the material, so regardless of whether you use HSS or carbide cutters, supply a cold air feed to the cutting area, and don't be afraid of cutting quickly. Cut slowly and you run the risk of melting the plastic.
And as stated before, 2 flutes will clear your chips more easily.
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
NEW MEMBER: Re my question
By oldwoodworker in forum New Member IntroductionsReplies: 32Last Post: 20-09-2013, 09:07 PM -
question ...
By Wobblybootie in forum General DiscussionReplies: 6Last Post: 04-01-2010, 12:04 AM -
A question
By bodgeitandscarper in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 02-12-2009, 08:30 AM
