It probably is voltage drop if thats all you have done and sure you haven't messed up the wires. Thou the Speed reference voltage must have been on the low side to start with for only 1mtr to affect it that much.
Often the Voltage source is 10V but using a Pot etc you never actually get 10v which the speed controller needs for full rpm.
Start by measuring the voltage at full speed and see what you get. You may need a higher voltage source like 12V to get full 10V for the speed controller.
12-10-2015 #2
Thanks for your response. The wiring is all correct as the spindle spools up smoothly as before but seems to top out at a lower RPM. For further info, the wiring was about 1.2m in length, now extended to about 2.5m.
I lack some electrical knowledge. Which pins on the speed controller should I measure between to get the voltage reading mentioned above. And should it result in being lower than the 10v suggested, how would I go about boosting it? The speed controller itself is supplied with 48v.
Many thanks,
12-10-2015 #3
Well to be fair if your not electrically minded then I suggest you don't mess around because depending on the Speed controller type the voltages can be at mains potential and dangerous if poking around not knowing what your doing.!! Suggest you try to find someone electricly savy to help with this.
Arc movement issue
By lukecnc2012 in forum Metalwork DiscussionReplies: 4Last Post: 09-08-2015, 07:15 PM -
THC Setting Issue?
By Davek0974 in forum Plasma Table MachinesReplies: 8Last Post: 17-10-2014, 07:53 AM -
Screw Dive Size Reduction ??
By manofgresley in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 04-09-2013, 05:34 PM -
TB6560 auto current reduction
By Mjolinor in forum Motor Drivers & ControllersReplies: 1Last Post: 08-12-2011, 09:53 PM -
Motor size 23' and 2/1 reduction for Z axe on SX3 retrofit.
By A2P in forum Linear & Rotary MotionReplies: 0Last Post: 15-09-2010, 05:14 PM
