    Quote Originally Posted by gabi68 View Post
    Since my spindle cable is floating I would like some opinions about how I mount that on the router without affect the stepper lines.
    Many thanks
    Gabi
    I went for the 'safe' option of not running in the router frame at all, although I've noticed that Dean's machines tend to run the spindle cable in some energy chain back to the Y carriage so if you take the precautions you can run it on the machine frame.
    Here is my very old machine but you can see the simple hook arrangement which allows the machine to move around:
    BUT - if you have this sort of GX16 screw-on connector to the spindle it will work loose on the pins over time and in case you don't know you must not allow a break in the circuit when under power. It will almost certainly kill the VFD stone dead - ask me how I know! :
    So you can replace the connector with a strain relief grommet (see top of spindle):
    Plus solder the cables direct to the motor by removing the end cap.
  1. Water cooled / air cooled 2.2kw spindle
    By suesi34e in forum Generic Chinese Spindles
    Last Post: 25-02-2015, 04:57 PM
  2. Drawing of water cooled spindle
    By GTJim in forum Spindles & Drive Motors
    Last Post: 11-02-2014, 04:21 PM
  3. Do you need to water cool erhm a water cooled spindle?!!
    By HankMcSpank in forum Generic Chinese Spindles
    Last Post: 02-10-2013, 09:59 PM
  4. Replies: 17
    Last Post: 18-09-2013, 06:32 AM
  5. water cooled spindle
    By alex wight in forum Generic Chinese Spindles
    Last Post: 21-09-2012, 09:57 PM
