Hi Jazz,
I did not wire the spindle, but I think if I put live to R/L1 and neutral to S/L2/N and earth to ground main side and UVW to spindle side I will be OK.
Spindle is 24000 RPM, 400HZ, 220V, 8.5A, 3 phase.
My problem lies on the parameter side. I read the manual and I am not to confident which parameter I need to change and with what.
Can you help?
Thank you
GabiLast edited by gabi68; 08-10-2015 at 11:12 PM. Reason: giving details
09-10-2015 #2
there are usually only 4 important parameters:
- Basefrequency (400Hz) - if you leave this to 50Hz you spindle may have a very short life.
- Maxfrequency (400Hz) - so you're able to reach 24000rpm
- Minfrequency (100Hz) - sets the lowest rpm (6000 rpm). You an go a bit lower but the spindle will have close to no torque below this point anyways.
- Acceleration (and deceleration) time (1 or 2 seconds are OK)
Be careful - VFDs are no toys - they can kill you even if you have an RCD installed in your house.
Christian2D / 3D CAM Software and CNC controller: http://www.estlcam.com
Water cooled / air cooled 2.2kw spindle
By suesi34e in forum Generic Chinese SpindlesReplies: 15Last Post: 25-02-2015, 04:57 PM -
Drawing of water cooled spindle
By GTJim in forum Spindles & Drive MotorsReplies: 5Last Post: 11-02-2014, 04:21 PM -
Do you need to water cool erhm a water cooled spindle?!!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 18Last Post: 02-10-2013, 09:59 PM -
Cooling a water cooled spindle, without pipes everywhere & huge water tanks/buckets!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 17Last Post: 18-09-2013, 06:32 AM -
By alex wight in forum Generic Chinese SpindlesReplies: 1Last Post: 21-09-2012, 09:57 PM
