    There's a kerning fault with the lettering, but the cutting looks good.
    You almost always need to manually kern in cad as very few software packages do the job well.
    Hi all,
    Thanks to everyone who has replied.
    I have been doing some experimenting and have identified the problem. I originally had some backlash issues with the gearbox that drives the 2 pinions, it turned out it was a stretched belt ( my own fault from over tightening ) After i sorted that out i was still getting slight lines on profile cuts ie. 3 passes- slight step on each, and as it seemed to be occuring at a point where the axis changed direction i didnt look elsewhere for the problem. I was cutting on Fri and i got this massive step (see picture) which made me realise the problem was with lost steps and not backlash.
    This is where i am looking for some advice ... i contacted the company i bought motors, drivers and gearboxes off. The drivers are leadshine Dm856 and the motors are 4.5nm. They are running off a 70v power supply. I suspected at the time of purchase the motors where slightly undersized but i was assured they (the company i purchased from) ran a similar sized machine with a similar weight gantry from these motors and drivers. I am using an ethernet smoothstepper as my controller. The company reckon mach3 is possibly the problem (they use Usbcnc) But so many people use mach 3 with no problems ,i have doubt that this is the case.
    As you can probably see from my pictures i have built this on a budget (no hiwins on X etc.) But it runs very smooth and is very very sturdy. My point is ,this machine will be in use most days as part off my business and i need it to be reliable. Am i as well just biting the bullet and purchasing bigger motors and drivers now , or are these correctly sized ?
    Sorry this is so long and rambling :)
    Thanks Philip
  1. Boring Bar Suggestions?
    By Washout in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 21-06-2014, 08:59 AM
  2. Cooling pump suggestions
    By martin54 in forum General Electronics
    Last Post: 13-02-2013, 09:07 PM
  3. Power Supply Suggestions please..
    Last Post: 30-01-2013, 06:37 PM
  4. Driver suggestions
    By Shinobiwan in forum Motor Drivers & Controllers
    Last Post: 04-03-2012, 03:54 PM
  5. PLC/Programmable chip suggestions
    By m_c in forum General Electronics
    Last Post: 02-04-2011, 04:40 PM
