Thread: Bulb replacement
Hi eveyone. Quick q: how do you know when your laser bulb needs replacing. Mine has literally just stopped working. Its pretty dirty looking. Any other clues?
19-01-2016 #2
Dirty? Got green algae living in the tube? If so then you will need to replace it. The water you run through the tube must be deionised and also have a bit of antifreeze for good measure.
You can try flushing through with bleach but chances are the tube is toast.
When a tube dies, it usually makes a fizzing sound like it is losing air, the intensity is dramatically reduced and finally stops working.
https://www.youtube.com/watch?v=_UyqTSe0tMsLast edited by komatias; 19-01-2016 at 11:04 PM.
https://emvioeng.com
Replacement Boxford 160 chuck
By Saracen in forum Boxford LathesReplies: 3Last Post: 21-01-2016, 06:53 PM -
Replacement Part Required.
By wildfowler54 in forum Bridgeport Milling MachinesReplies: 4Last Post: 06-01-2016, 08:42 PM -
Replacement brushes needed for Champion 20v (BF20 clone)
By davegrennan in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 15-07-2015, 10:54 PM -
Hi replacement moons motor driver sr4h
By cockneyrebel in forum General DiscussionReplies: 2Last Post: 24-02-2015, 03:41 PM -
Romi EZ-Path S Lathe crt replacement
By Nemo1966 in forum MonitorsReplies: 5Last Post: 07-10-2013, 04:25 PM
