Thread: Laser for under £2000?
Burning images on wood is easily done with a low power laser. Its cutting that is not.
40W will cut through pine, 50W will cut birch ply. of course it depends on the speeds you run at. engraving can be done quicker than cutting as it only chars the surface.
I have recently bought my girlfriend a the 50W chinese laser from ebay at the bottom of the link you shared. It is easy to use but the software is a bit limited. If they had the 60W at the time, I would have bought that one. Gutted I hadnt seen it :(
Build quality is not bad for the price either. Just be sure that it is in your country already so you do not get slapped with the import duties.
If you want to do greyscale though then you will either have to do it manually by splitting layers or pay more money for a control.Last edited by komatias; 11-10-2015 at 12:14 AM.
https://emvioeng.com
12-10-2015 #2
Have you considered using a high powered 445 diode for just engraving? You could even combine a few together for double power
FOR SALE: Multicutter 2000 3M * 4M 3 axis router
By gavztheouch in forum Items For SaleReplies: 24Last Post: 09-03-2013, 11:43 AM -
Sherline 2000 CNC Mill
By cooliced in forum Sherline MillsReplies: 37Last Post: 12-01-2013, 10:22 PM -
NEW MEMBER: Hello from Staff 2000
By Alex@staff2000 in forum New Member IntroductionsReplies: 1Last Post: 21-11-2009, 12:23 AM -
Mach 2 / 3 - Windows 2000/XP
By teetat in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 10-07-2009, 02:47 PM -
Best cnc mill for under £1500-£2000
By xchipx in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 05-03-2009, 08:42 PM
