13-10-2015 #17
One more question which is probably more about Mach3...
It used to be that if I used 'Run From Here' command it would rapid to the start location at a safe Z height. Now it seems to descend to Z=0 to move. How can I fix that?
EDIT: Ahh sorted it. There was a 'Safe_Z Setup' option to set in the 'Config' menu. For some reason I don't recall ever setting this in the past. I did install the latest Mach 3 when adding the ESS.Last edited by Tenson; 13-10-2015 at 06:19 PM.
Connecting to a CNC machine, pros and cons of USB vs PP vs Ethernet etc.
By Jess in forum Control Hardware & SystemsReplies: 76Last Post: 20-05-2021, 02:51 PM -
USB/Ethernet controller for Mach3/4 advice
By paulus.v in forum Control Hardware & SystemsReplies: 17Last Post: 17-02-2015, 09:37 PM -
how to smooth stl model, smooth curves out of straight lines
By chris in forum DeskProtoReplies: 4Last Post: 21-01-2014, 11:00 PM -
USB and Ethernet Mach3 motion controller PLCM-E3
By Purelogic R&D in forum Manufacturer NewsReplies: 39Last Post: 29-12-2012, 09:38 AM -
Threaded bar, steper motor and a plasma cutter.. your thoughts?
By gr8fun in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 27-11-2012, 05:14 PM
