Oh, what about the step and direction pulse width in motor tuning? It seems both are set at 5us by default (says 1-5us range).
It strikes me that it could be longer when running at a 32KHz 'Maximum Step Frequency', because 5us is the same as 200KHz. Am I right in thinking a longer step and direction pulse could give more reliability?Last edited by Tenson; 13-10-2015 at 12:37 AM.
13-10-2015 #2
Leave the pulse width as it is on the motors tuning page. Quoting from a conversation I had a while ago: "pulse width" settings in the Motor Tuning dialog do nothing". Neither does the option on ports and pins menu regarding the clock speed (25, 35, 45 khz)
Your Smoothstepper will by default run at 250kHz, This is set in the plugin control menu for the ESS.
https://emvioeng.com
13-10-2015 #3
In motor tuning, the step and direction pulse widths are totally ignored by the SmoothStepper. As a hardware vendor and plugin designer we just have no way to hide those fields in the main app.
Here is a page that answers this and other similar questions about Mach3.
AndyLast edited by AndyFromWarp9TD; 13-10-2015 at 03:38 PM.
13-10-2015 #4
Thanks, yes it makes sense that the step frequency is setting the pulse width - it's just a different way to say the same thing.
Do you think the 1KHz Controller Frequency will be fine for my old Pentium 4 laptop?Last edited by Tenson; 13-10-2015 at 03:46 PM.
13-10-2015 #5
Actually, step frequency is not the same same thing as pulse width; lets use some easy numbers for math:
- You have a 1 kHz pulse frequency, which means you have 1000 pulse occurring per second, or one every ms
- If the pulse had a 50% duty cycle (on half the time off half the time) it would be on for 0.5ms or 500 us for its pulse width.
- If the pulse had a 1% duty cycle, it would have a pulse with of 10 us and then be off for 990 us.
- If the pulse had a 90% duty cycle, it would have a pulse with of 900 us and then be off for 100us.
Step frequency is how often the pulses are being generated. Pulse Width is how long each pulse is on before it turns off to await for the next pulse to be generated.
Start with 1 kHz. You can adjust from there later if you need too, but you probably won't.
~AndyLast edited by AndyFromWarp9TD; 13-10-2015 at 03:53 PM.
13-10-2015 #6
Begs the question, what do the step and dir pulse length do in the mach3 menu when using their PP driver, if the pulse length is determined by the desired velocity?
13-10-2015 #7
So I have never used the parallel port in Mach3 since I have always used a SmoothStepper. My *guess* is that if you use a 1 us wide pulse, they will come out 5x more often that a 5 us wide pulse would. The higher number of pulses would make the system more responsive, but you might miss a pulse easier. Again, I am guessing how they are doing it in the parallel port version since we just ignore those parameters in motor tuning.
13-10-2015 #8
Sorry Tenson I've only just seen your PM but looks like you have been sorted by none other than the Man himself.!!. we are honoured.!!. . Lol
This probably answers the question why plug-in's never get finished. . .
Connecting to a CNC machine, pros and cons of USB vs PP vs Ethernet etc.
By Jess in forum Control Hardware & SystemsReplies: 76Last Post: 20-05-2021, 02:51 PM -
USB/Ethernet controller for Mach3/4 advice
By paulus.v in forum Control Hardware & SystemsReplies: 17Last Post: 17-02-2015, 09:37 PM -
how to smooth stl model, smooth curves out of straight lines
By chris in forum DeskProtoReplies: 4Last Post: 21-01-2014, 11:00 PM -
USB and Ethernet Mach3 motion controller PLCM-E3
By Purelogic R&D in forum Manufacturer NewsReplies: 39Last Post: 29-12-2012, 09:38 AM -
Threaded bar, steper motor and a plasma cutter.. your thoughts?
By gr8fun in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 27-11-2012, 05:14 PM
