    Iv an Emco PC Turn 55 I am retro fitting with Linuxcnc. It comes with a 3 phase AC motor. I can't seem to find the specs of the motor. I'm sure it's either 50hz or 60hz. I have a VFD setup. If I run the motor at 50hz, the spindle is at about 1200rpm on the fastest pulleys. If I double the frequency to say 100hz. Will this damage the motor? Motor bearings will be obviously running hotter but can the increased frequency fry the motor?
    I have run a variety of fairly new, good quality Inverter Duty Rated 3 phase motors at 0-200% of plated speed without issues, I ran an Electro-Adda (Italian) 1hp compact frame 2 pole motor at 7000 rpm for extended periods and it's still running.
    Thank you I managed to get the plate on the motor. AEG make some pretty good motors as far as I know.
  1. EMCO PC Turn 50 specs.
    By PeterE in forum Emco Lathes
    Last Post: 30-09-2020, 05:23 PM
  2. WANTED: Emco PC turn 120/125/155 or Emco Concept turn 105
    By Maxiscnc in forum Items Wanted
    Last Post: 11-04-2020, 09:10 AM
  3. emco pc turn 55 conversion to mach3
    By Geoff57 in forum Machine Discussion
    Last Post: 02-02-2019, 06:21 PM
  4. emco pc turn 55
    By geoff in forum Emco Lathes
    Last Post: 11-07-2018, 05:15 PM
  5. Emco PC120 Turn
    By Chaz in forum Emco Lathes
    Last Post: 14-08-2017, 09:47 AM
