18-10-2015 #1
Need advice on new machine, i am total beginner with cnc.
Need for make pcb circuit with drilling holes. And easy software to work with.
Price is 400-800 USD
Making PCBs this way is very slow, you know?
IME it is better to use a professional fabricator - http://www.kikipcb.com/
Unless you are making rather crude and large PCBs it's a tough job for a mill to do a good job. My PCBs have tracks only 0.2mm wide and similar spacing, that is a difficult ask for an affordable mill.
18-10-2015 #3
I use a combination of Eagle to do the design work and the pcb-gcode ulp to generate the necessary gcode files. For the small one off type of thing that I do as a hobbyist, this works fine.
The ulp can be found either on the Eagle site or there is a yahoo group dedicated to it.Art
AKA Country Bubba
(Older than Dirt)
18-10-2015 #4
I need for small job. Maybe 4-5 pcs pcb year
Example for my job.
http://i01.i.aliimg.com/wsphoto/v0/1...font-b-ECU.jpg
18-10-2015 #5
It looks like those boards might easily be handled by Eagle Lite (no cost for a hobbist) and the ulp is also no cost.
Might be a winner setup for you.Art
AKA Country Bubba
(Older than Dirt)
18-10-2015 #6
So it is free card for eagle lite?, Would be fun to try cnc , but no one has tips on a cnc router with good price and easy to use!
18-10-2015 #7
I built my router (about 330mm x 330 mm x ~50mm) and control it with an old DOS program called Turbocnc.
The router was built with and aluminum channel and flat stock. I found some linear rails to use for the X, Y, and Z. Managed to get a spindle (only 70 watts but works for PCB work). used acme lead screws with derlin nuts for zero backlash.
Works for me.Art
AKA Country Bubba
(Older than Dirt)
18-10-2015 #8
How many PCB can you buy for the cost of a router?
18-10-2015 #9
I do it because I CAN and want to do it. Its not a money thing. I do it to prove to myself that I can. A hobby is not all about saving money, sometimes it is proving that you can do it yourself. If it was all about saving money, I would not have any hobbies and simply buy whatever it is. Also, my hobby projects are typically one off types. I have no plans to manufacture a product. So I can go from a board design to finished board ready to populate in less than an hour usually. How quick can you get a turn around on the board (one off) that you want to buy???
Its different strokes for different folks.Art
AKA Country Bubba
(Older than Dirt)
The Following 3 Users Say Thank You to C_Bubba For This Useful Post:
18-10-2015 #10
Flasher circuit using a BD679
By ozspeedway in forum General ElectronicsReplies: 15Last Post: 12-07-2014, 08:39 AM -
AM882 Alarm Circuit
By Wobblycogs in forum General ElectronicsReplies: 8Last Post: 28-03-2014, 06:06 PM -
-10V to 10v circuit
By vre in forum General ElectronicsReplies: 17Last Post: 15-01-2014, 12:15 AM -
E-STOP Circuit - will this cause any problems?
By birchy in forum General ElectronicsReplies: 34Last Post: 18-12-2012, 04:35 AM -
DC motor drive circuit?
By Tenson in forum General ElectronicsReplies: 4Last Post: 02-02-2012, 10:32 PM
