    So it is free card for eagle lite?, Would be fun to try cnc , but no one has tips on a cnc router with good price and easy to use!
    C_Bubba's Avatar
    Lives in LaGrange, GA USA, United States. Last Activity: 18 Hours Ago Has been a member for 9-10 years. Has a total post count of 78. Received thanks 10 times, giving thanks to others 2 times.
    I built my router (about 330mm x 330 mm x ~50mm) and control it with an old DOS program called Turbocnc.
    The router was built with and aluminum channel and flat stock. I found some linear rails to use for the X, Y, and Z. Managed to get a spindle (only 70 watts but works for PCB work). used acme lead screws with derlin nuts for zero backlash.
    Works for me.
    Art
    AKA Country Bubba
    (Older than Dirt)
    How many PCB can you buy for the cost of a router?
    C_Bubba's Avatar
    I do it because I CAN and want to do it. Its not a money thing. I do it to prove to myself that I can. A hobby is not all about saving money, sometimes it is proving that you can do it yourself. If it was all about saving money, I would not have any hobbies and simply buy whatever it is. Also, my hobby projects are typically one off types. I have no plans to manufacture a product. So I can go from a board design to finished board ready to populate in less than an hour usually. How quick can you get a turn around on the board (one off) that you want to buy???
    Its different strokes for different folks.
    Art
    AKA Country Bubba
    (Older than Dirt)
  5. The Following 3 Users Say Thank You to C_Bubba For This Useful Post:
  6. #5
    I built my first cnc for the very same reason as alfons37. Took me a while to even get as far as trying to route a pcb. You gotta learn how to cnc before you start on a pcb. Then theres the added complication of levelling, alignment pins for double sided etc pretty soon it all gets pretty darn hard. Prepare to destroy a load of copper boards. You gotta keep in mind when designing the boards that you can expect to route 0.1mm gaps easily so you need to keep your pcb design modest.
    To get to the op's question, the machine you need will need to be super precise but not necessarily super strong, if knocking a few microns of copper off the top of a board is all the stress it will get. The chinese machines may well do the job, but you cannot be sure of what you are going to get with one of these. However given your budget, your choice is a cheap chinese machine or none at all.
  8. The Following User Says Thank You to davegrennan For This Useful Post:
  9. #7
    Quote Originally Posted by C_Bubba View Post
    Well said that Man.!! . . . Exactly how I got into CNC and one of the things that still motivates me.!
  10. #8
    C_Bubba's Avatar
    Thanks Jazz
    At my age, it is projects like this that make me want to get up in the morning and do something instead of sitting around the house all day. I like staying home and putzing around in the shop or dreaming up new projects.
    Art
    AKA Country Bubba
    (Older than Dirt)
  11. #9
    I do it because I CAN and want to do it. Its not a money thing. I do it to prove to myself that I can. A hobby is not all about saving money, sometimes it is proving that you can do it yourself. If it was all about saving money, I would not have any hobbies and simply buy whatever it is.[...]
    Saying thanks wasn't enough for me. It's been a while I haven't read one like that. To me, even if the things I make myself never pay back for what I spent for the machine, it's all about the fun to design it, make it, and see it coming to life. That, is priceless. Sorry if I'm off topic, but I couldn't hold myself from sharing :)
  12. #10
    My question was actually to the OP who doesn't already have a CNC machine and doesn't have the skills yet. If his goal as set out in the first post is to produce a few PCBs, it will be less expensive and return better quality to use the manufacturer I linked to. £30 will land you a handful of PCBs delivered to your door.
    On the other hand, if you are doing this as a hobby then a CNC machine will give you a lot of joy and be highly useful! Alfons37 what is your ultimate goal?
  1. Flasher circuit using a BD679
    By ozspeedway in forum General Electronics
    Last Post: 12-07-2014, 08:39 AM
  2. AM882 Alarm Circuit
    By Wobblycogs in forum General Electronics
    Last Post: 28-03-2014, 06:06 PM
  3. -10V to 10v circuit
    By vre in forum General Electronics
    Last Post: 15-01-2014, 12:15 AM
  4. E-STOP Circuit - will this cause any problems?
    By birchy in forum General Electronics
    Last Post: 18-12-2012, 04:35 AM
  5. DC motor drive circuit?
    By Tenson in forum General Electronics
    Last Post: 02-02-2012, 10:32 PM
