    I built my router (about 330mm x 330 mm x ~50mm) and control it with an old DOS program called Turbocnc.
    The router was built with and aluminum channel and flat stock. I found some linear rails to use for the X, Y, and Z. Managed to get a spindle (only 70 watts but works for PCB work). used acme lead screws with derlin nuts for zero backlash.
    Works for me.
    Art
    AKA Country Bubba
    (Older than Dirt)
    How many PCB can you buy for the cost of a router?
    I do it because I CAN and want to do it. Its not a money thing. I do it to prove to myself that I can. A hobby is not all about saving money, sometimes it is proving that you can do it yourself. If it was all about saving money, I would not have any hobbies and simply buy whatever it is. Also, my hobby projects are typically one off types. I have no plans to manufacture a product. So I can go from a board design to finished board ready to populate in less than an hour usually. How quick can you get a turn around on the board (one off) that you want to buy???
    Its different strokes for different folks.
    Art
    AKA Country Bubba
    (Older than Dirt)
  4. The Following 3 Users Say Thank You to C_Bubba For This Useful Post:
  5. #4
    I built my first cnc for the very same reason as alfons37. Took me a while to even get as far as trying to route a pcb. You gotta learn how to cnc before you start on a pcb. Then theres the added complication of levelling, alignment pins for double sided etc pretty soon it all gets pretty darn hard. Prepare to destroy a load of copper boards. You gotta keep in mind when designing the boards that you can expect to route 0.1mm gaps easily so you need to keep your pcb design modest.
    To get to the op's question, the machine you need will need to be super precise but not necessarily super strong, if knocking a few microns of copper off the top of a board is all the stress it will get. The chinese machines may well do the job, but you cannot be sure of what you are going to get with one of these. However given your budget, your choice is a cheap chinese machine or none at all.
  7. The Following User Says Thank You to davegrennan For This Useful Post:
  8. #6
    Quote Originally Posted by C_Bubba View Post
    Well said that Man.!! . . . Exactly how I got into CNC and one of the things that still motivates me.!
  9. #7
    Thanks Jazz
    At my age, it is projects like this that make me want to get up in the morning and do something instead of sitting around the house all day. I like staying home and putzing around in the shop or dreaming up new projects.
    Art
    AKA Country Bubba
    (Older than Dirt)
  10. #8
    I do it because I CAN and want to do it. Its not a money thing. I do it to prove to myself that I can. A hobby is not all about saving money, sometimes it is proving that you can do it yourself. If it was all about saving money, I would not have any hobbies and simply buy whatever it is.[...]
    Saying thanks wasn't enough for me. It's been a while I haven't read one like that. To me, even if the things I make myself never pay back for what I spent for the machine, it's all about the fun to design it, make it, and see it coming to life. That, is priceless. Sorry if I'm off topic, but I couldn't hold myself from sharing :)
  11. #9
    My question was actually to the OP who doesn't already have a CNC machine and doesn't have the skills yet. If his goal as set out in the first post is to produce a few PCBs, it will be less expensive and return better quality to use the manufacturer I linked to. £30 will land you a handful of PCBs delivered to your door.
    On the other hand, if you are doing this as a hobby then a CNC machine will give you a lot of joy and be highly useful! Alfons37 what is your ultimate goal?
  12. #10
    alfons, I just thought I'd return here and add a few pointers that I've picked up while taking my first steps into milling PCBs. Hopefully these will save you a few ruined copper boards!
    First level is everything, if your board is not EXACTLY perpendicular you cannot take the really shallow cuts that you would like. Either you will cut too deep in some parts or cut air in others. Set up a touch probe and use something like autoleveller software to level your gcode with your workpiece. It really did the business for me.
    I found that MFD makes a particularly good spoilboard for pcbs. Use double sided tape to hold down the copper board. Using clamps just bends the board! A few strips of tape is strong enough to hold it secure and is easy to get off afterwards.
    Use alignment pins for double sided boards. You just cannot line uop accurately enough just flipping the board by eye, even using marks on the spoilboard.
    Keep in mind that as holes are not plated through you could (likely) have great difficulty in soldering some components, use smd where possible. If you are used to working with commercial grade boards with resist and solder mask etc, its easy to forget this and then realise you cannot actually complete your shiny new cnc made board (happened to me).
    Lastly keep your designs modest and your tracks as fat as possible. Even using 0.1mm V bit, its very difficult to actually cut 0.1mm in copper, expect maybe 0.3mm. I'm sure with more experience it will be possible to get thinner cuts. And keep in mind that the extra cut width will come off your track, so it will be narrower than planned.
    Hope some of this is helpful to you when you do get to finally mill some copper.
  1. Flasher circuit using a BD679
    By ozspeedway in forum General Electronics
    Last Post: 12-07-2014, 08:39 AM
  2. AM882 Alarm Circuit
    By Wobblycogs in forum General Electronics
    Last Post: 28-03-2014, 06:06 PM
  3. -10V to 10v circuit
    By vre in forum General Electronics
    Last Post: 15-01-2014, 12:15 AM
  4. E-STOP Circuit - will this cause any problems?
    By birchy in forum General Electronics
    Last Post: 18-12-2012, 04:35 AM
  5. DC motor drive circuit?
    By Tenson in forum General Electronics
    Last Post: 02-02-2012, 10:32 PM
